air intake
Old Mar 7, 2004 | 11:51 PM
chasmc2's Avatar
air intake
I have a 2.4 and checking into getting rid of the box and going with a k&n but I have seen on ebay a air intake adapter filter. for hundreds cheaper. can anyone guide me in the right direction
Old Mar 8, 2004 | 01:08 AM
JEDI87's Avatar
Filter
I bought won of those filters off of ebay for like 25 bucks.It works great.I noticed better throttle response,power, and gas mileage.Plus I now have that cool whistle from the intake.
Old Mar 8, 2004 | 04:23 AM
ElwayLite's Avatar
I bought one for my 3.4 off of ebay for $105, it looks great and fit perfectly.
Old Mar 8, 2004 | 06:05 AM
PirateFins's Avatar
Don't know if your airbox is setup the same as mine but here is what I did.
I removed the intake elbow (inside the air box) and "S" tube from where they come in from behind the headlight. I then opened up the corner of the airbox where "S" tube left a hole, to a 4"x4" square opening. Drilled holes in the bottom of the box to let any water that might get in drain out. Then I just went with the drop in K&N filter in the stock box. This made a noticable difference. And also added that cool intake sound.
The 1.5" intake tube that is inside the airbox comming from the 2" intake "S" tube from the headlight area were super resrictive. Try this method first if you don't want to spend alot of money. The only thing I had to buy was the new drop in filter. I can take pics of what the modified box looks like if you are interested.
Brad
Old Mar 8, 2004 | 07:57 AM
humanoid's Avatar
Brad
Brad:
I'd was thinking about going back to the stock intake box and doing the same thing. Some pics of the mods would be great for me as well as others. Plz post them if ya can!
Old Mar 9, 2004 | 09:57 AM
chasmc2's Avatar
air intake
Brad
Brad I am intrested in the pics. I stopped by a pro shop and they told me that the stock air box is the best to go if you plan on going through mud or water.
thanks and talk to you soon. look forward for the pics
Old Mar 9, 2004 | 10:49 AM
PirateFins's Avatar
Ok for all that want to see pics I will work on them this week end. I have all of the parts still except for the cutout section. I will try and put it back to stock and show a step by step progression.
Old Mar 9, 2004 | 07:51 PM
javadoody's Avatar
brad;
for what it's worth. i pulled my box and removed the interior elbow that runs off the headlight "s". on the back radiator side of the airbox is another uncut circle. i assume this is for another application of the same airbox. i cut out that hole and riveted in the elbow i removed, giving another intake to the box, but pointing it forward to attempt to pick up colder incoming air. my amzoil filter will be in this week. even with the paper filter there is a nice throaty sound and a bit more giddy-up.
there have been numerous discussions on this site regarding amzoil versus k+n filters, as well as a airbox mod with deckplate for a 4runner. the amzoil, with airbox mods, increased the hp and maintained filtration far better than k+n. i'll try to relocated these posts if you'd like to read them.
gary
Old Mar 9, 2004 | 08:02 PM
chasmc2's Avatar
Originally Posted by javadoody
brad;
gary
That would be great. im getting ready to buy the filter so getting the best one would be a +
thanks
Old Mar 10, 2004 | 04:53 AM
PirateFins's Avatar
brad;
gary
Gary,
I thought about doing that also but decided to leave that hole plugged. I didn't want to reuse the elbow since bends are not condusive to nice flow, but every little bit helps. By removing the "S" pipe I have a larger area to pull air into + it left a hole in the headlight cover to allow fresh cool air to flow in at speed. I also have read the numerous post on the filters (thanks Gadget) and just haven't gotten around to replacing the K&N with the Amzoil. I came up with the idea for the airbox mod, based on the similar Deckplate Mod and Elbow removal mod's that the guy's with the V6's have done. I didn't see alot on moding a 22RE airbox so I thought I would take a stab at it. And you are right it makes a difference. I have been running that setup for 1yr now and I am happy.
Old Mar 10, 2004 | 06:23 AM
javadoody's Avatar
Gary,
thanks, i think i'll do the same with the "s". you're right, the less bends the better--i was concerned i'd pull air right off the fan and radiator and was attempting, in a meager way, to pick up colder air. was thinking of pulling the plastic plug located right ahead of the coolant overflow tank (moving it out of the way first) and with a scoop, forcing air directly into the box.
for all that would like the writeup that we're talking about:
http://www.gadgetonline.com/airinduction.htm
i haven't found the original post yet (it's somewhat back in early feb.), but fortunately bookmarked the article on gadget's site.
good luck,
gary
Blamalam
Mar 12, 2022 07:34 AM
rusty904
Mar 27, 2017 05:20 PM
RatOmeter
Oct 22, 2015 03:17 PM
Tacoma1313
Aug 17, 2015 05:44 PM
Koolbananass
Aug 12, 2015 01:59 AM
