Adobe files for Urd install??
I'm about to start the install of the s/c and urd kit and since I bought the ftc and injectors used, I don't have the install guides for either. Does anyone have the install guide for the injectors and ftc for a 2001 tacoma 3.4 manual???
Ummm, dropping an email to Brian may help: info@urdusa.com
My email is Digger33@aol.com.
I did send an email to brian already wednesday night. I know they are way busy and I'm trying to start my install in the morning, so I thought I would post on here as well. I already had the two files I need but my computer they were on, broke and won't even turn on.
Originally Posted by outlaw27
The last post was by me (digger33), I'm using travis's brother's computer and I can't get him logged out.
Good luck on the install... The injectors are straight forward, once you get the top of the engine off, you'll see how to get the fuel rail off and th3e new injectors will plug right in. Did you get a fuel pump as well?
I wish I could help with the FTC - I've done a couple of the SMTs, but the wiring will be different and I'm not familiar enough with the SplitSecond software to help you set it up.
All I can say there is... good luck!
If you CAN'T get the FTC installed, then know that you will run VERY rich with the larger injectors (370's?). In fact, it may not start at all. I would almost suggest that you NOT install the injectors until you can find the instructions for the FTC.
You've got a big day in front of you... have fun with it!
Ya i tried the log out thing but it still didn't work, so I'm still on travis's name. I think it's set to always log that name on, on this computer. Anyways, I have the 318 injectors that come with the urd kit. I'm going to begin with the thermostat and fuel pump today and hopefully I can get the files later on today or tonight and do the charger, injectors and ftc either later on or tomorrow.
anniesball
12
Sep 30, 2015 08:09 AM
punks_is_4x4
Aug 21, 2015 01:35 PM
anniesball
Jul 29, 2015 11:46 AM
