add on gauge questions
Old Sep 9, 2005 | 03:45 PM
masterwacker's Avatar
I am looking at buying some more guages for my truck. 93 P/U 3.0 manual tranny, 4wd. Do any of you know for the guages listed below do I need mechanical gauges or electrical guages
water temp - for radiator
oil temp
oil pressure
Thanks
Old Sep 9, 2005 | 05:36 PM
4Crawler's Avatar
You can use either type for the pressure ones. W/ electric gauges, you install senders and run wires back for the gauges. W/ mechanical, you run tubing back. I like electical gauges since you don't have tubes with oil under pressure in the cab. See http://www.egauges.com/ for some info.
Old Sep 9, 2005 | 08:11 PM
great site you sent me to 4crawler. The site answered all my questions that I had and the ones I didn't even know I had yet. Am I correct in assuming that for the pressure and temp gauges, electrical ones that is, that you splice in a T with the correct NPT threads to install the sending unit? Where would be a good place to install these sending units for
water temp
oil pressure
oil temp
I am also assuming that it would be a good idea to fuse the 12V power to the gauge? Would and inline bus fuse be appropriate. I can't see the gauge needing anything more than a 10 amp fuse since the wires are only 18 gauge.
Thanks
Old Sep 9, 2005 | 08:14 PM
well, I just found your site. If there is anything else you would like to add please do so though. Thanks for the info.
Old Sep 9, 2005 | 08:28 PM
Bob_98SR5's Avatar
master,
though this is for a 98 4runner, here's my write up on an oil pressure gauge install:
http://www.4runners.org/articles/gaugeoil
bob
Old Sep 9, 2005 | 08:44 PM
good write up bob, if I have a port like that I can install the temp and pressure sending unit there with the use of a T fitting. So that solves those two. The one I am curious about those is the water temp for the radiator. Any ideas?
Old Sep 9, 2005 | 09:31 PM
4Crawler's Avatar
Dig around on your engine looking for locations. Not familiar with the V6, but on the 22RE there are lots of options. One thing I did on my VW is to use the dual output VDO senders for my add-on gauges. Then I removed the idiot light sender for say the oil pressure and screwed in a dual output sender with a contact for the idiot light and an analog output for the new gauge. Or find the stock temp sender and remove it, insert a tee fitting and screw in the old and new sender. On my '85, I added a fuel pressure guage by drilling and tapping the end of the fuel injector rail. Then I soldered in a brass pipe fitting (to make sure it was secure and totally sealed) then screwed the pressure sender into it. On an old vehicle I had, I also drilled and tapped one of the water hose fittings for a temp sender. It was screwed in and then sealed up with some epoxy. Just need to get creative with the sender locations.
bigjstang
Jun 2, 2025 03:56 PM
the1998sr5
15
Jul 14, 2020 08:35 PM
Nickyodaman
Jul 27, 2015 12:13 AM
88yodabasket
Jul 13, 2015 01:32 PM
Poncho0206
Jul 10, 2015 06:21 PM
