A340F fluid interval
Old Mar 4, 2009 | 08:21 AM
raydouble's Avatar
Anyone know the recommend oil change schedule for the auto trannys?
Didn't see it in my owners manual or FSM.
75k......100k
Old Mar 4, 2009 | 08:37 AM
BigBallsMcFalls's Avatar
30K
hint: google
Old Mar 4, 2009 | 08:44 AM
raydouble's Avatar
Originally Posted by BigBallsMcFalls
30K
hint: google
lol
I must not have been searching with the right terms, I didn't see anything.......
30k seems short, oh well, more work to do.
Old Mar 4, 2009 | 11:03 AM
toyota 4runner atf change interval
that is the google search term
and it results in this
http://www.4x4wire.com/toyota/mainte...tenancep4.html
Old Mar 4, 2009 | 11:20 AM
raydouble's Avatar
Word, thank you.
Old Mar 4, 2009 | 11:27 AM
mt_goat's Avatar
What year do you have? Sometime around 2002 or 2003 Toyota started using a different ATF, it may have a longer life I don't know.
Old Mar 4, 2009 | 11:39 AM
raydouble's Avatar
I've got an 01' Runner
Owners calls for Dex III....... I'm glad cause I can get from work.
Old Mar 5, 2009 | 05:40 PM
skjos's Avatar
I just did the whole pan drop & flush at 60K, and replaced the fluid with Amsoil. My ATF schedule is:
60K: Drop Pan, replace filter, flush
75K: Drain Pan, Refill
90K: Drain Pan, Refill
105K: Drain Pan, Refill
120K: Drop Pan, replace filter, flush
repeat...
Toyota recommends 30K if towing a trailer for ATF replacement (http://smg.toyotapartsandservice.com/index.php). I feel that using high quality ATF, using short interval drain/fills, and not overloading my transmission by towing; that I should be plenty fine with this schedule.
Old Mar 5, 2009 | 06:23 PM
86tuning's Avatar
If you're towing, just put in a large auxiliary transmission cooler and you'll be fine. When you inspect the fluid, look at the color and smell it. If it smells burnt, you're overdue for fluid change.
ladybugRC
458
Aug 21, 2020 10:41 AM
zanzabar0
Oct 11, 2015 02:56 AM
bradahman
Oct 1, 2015 09:24 AM
gentry
Sep 28, 2015 06:16 AM
old87yota
Sep 9, 2015 12:39 PM
