98 runner problems any help???
I have a 98 4 runner 4 cylinder and latley the check engine light has been coming on and turning off but sometimes it looses a little power and when I stop it idles really funny and really shakey the other day I pushed the gas and got no throttle response then I let off and pushed again and it took off... Also my brake light comes on as well sometimes and the other day while driving my breaks went out and I rolled to a stop lucky I was in the country we ran it on a innova diagnostics machine and it keeps saying auto air control valve and intake air sensor but i am thinking its something else me my dad and grandpa are having trouble figuring this out and my dad and grandpa are both former mechanics!!! any help/input would be appreciate!!! man just when I get the money for a lift and tires this stuff happens ohhh how the world works...
brakes don't suddenly out and then magically work again. Are you sure it didn't die and you lost power brakes? If you are braking without any vacuum it's gonna take 2 feet on the pedal to stop ur truck. Try cleaning your MAF and throttle body while you are it. Check the wiring etc.
well... its deffinetly a good idea to clean the maf sensor just make sure you use a maf safe cleaner and be careful with it. May want to pull the plugs and check either the plugs or make sure you're not filling the spark plug holes with oil or water. could case the ruff running and loss of power.
...Trending Topics
FS[MidWest]: 1995 4Runner 5vz 4x4
vasinvictor
Jan 20, 2016 12:39 PM
Mr.Black
Jun 21, 2015 10:17 AM
