96 4Runner popping
Old Jul 26, 2005 | 05:12 AM
96run's Avatar
96 4Runner popping
I have a 1996 4Runner w/ 125,000 miles and in the past few months it has produced a popping noise in left rear (?) when turning left. Really notice on slow turn just after accelerating into the turn.
I just replaced the rear swaybar bushings and that did nothing. Anyone have any other ideas? How would I check to see if it's the shaft or rear end??
It has nothing to do with 4WD or steering stops.
Thanks
Steve
Old Jul 26, 2005 | 05:36 AM
bamachem's Avatar
shock bushings may be cracked or gone...
Old Jul 28, 2005 | 05:53 AM
96run's Avatar
popping
I will look into that but can't imagine those being bad? I replaced the stock shocks a couple years ago with Bilstein shocks.
Old Jul 28, 2005 | 06:06 AM
cubuff4runner's Avatar
I was getting a noise like that a while ago and I found out that the panhard rod bolt had been worn down, so it was thinner and the rod was allowed to move, only a 1/32" or so but was enough to make noise. Good Luck.
Old Jul 28, 2005 | 06:11 AM
96run's Avatar
pop
panhard rod bolt? Could you elaborate a little more on what that part is, where and how to tell it's bad?
thanks
Old Jul 28, 2005 | 06:22 AM
The panhard rod is what keeps your axle from going side to side. It it the long rod that goes from your frame on the passenger side down to your axle on the driver side. I would just go under any try to move it, if it has any play remove the bolt and see it the bolt gets narrower in the middle. If so go to the hardware store and get a new one.
Old Jul 28, 2005 | 06:35 AM
96run's Avatar
pop
hmm...still not sure what this is? This thing is located at the rear but goes from left to right on the vehicle? I will try and locate this thing tonight.
Old Jul 28, 2005 | 06:40 AM
bamachem's Avatar
on the back side of the rear axle between the axle and where the spare resides. it will be about 1" in diameter and will cross from the frame of the runner on the pass side to the axle housing on the driver side. there are bolts in each end for it to pivot on. those bolts wear, allowing play in the panhard and can cause noise.
Old Jul 28, 2005 | 08:11 AM
96run's Avatar
Pop
well alright! Thanks for the picture! I can't say that I ever remember seeing this part and I am alway's looking under/washing the truck? Will take a look this evening and see what I find. I will post tomorrow with the details.
Thanks
Old Jul 29, 2005 | 04:32 AM
96run's Avatar
pop
I pulled on the panhard rod and did not produce any movement, back to square one.
Old Jul 29, 2005 | 10:52 AM
96run's Avatar
How do I check to see if my CV joint is going bad?
Old Aug 4, 2005 | 10:47 AM
Did you figure out what the noise was?
Old Aug 4, 2005 | 12:41 PM
arielb1's Avatar
Here is a link to your CV question. I have just repalced my axel. In the process I found my ball joint had a small tear on the rubber. It was harder to remove the ball joint than to remove the axel. Anyway, my truck is still apart. Hopefully after I put my truck together the clunk, thunk or popping noise goes away. I have 94 4X4 SR5 with 110K miles.
I was told by a axel rebuilding shop that a CV is bad when you take a very sharp turn forward or back and you hear a clanking noise. If you dont hear it, then the problem is not CV related....just my 1 cent. Replacing the axcel because the cv boot tore is easy enough. You just need the right sockets and wrenches. Oh, a breaker bar and PB helps.
Keep us posted with your issue please. I would like to know how you resolve it.
https://www.yotatech.com/forums/f2/thunk-clunk-noise-front-part-truck-something-63913/
icentropy
Sep 16, 2020 02:47 PM
mskalmus
May 28, 2017 07:51 AM
coreyedwards7611
Jan 16, 2016 06:38 PM
BeMiceElf
Oct 10, 2015 09:40 PM
horunner1x
Jul 10, 2015 06:33 AM
