96 4Runner MT fluid qty and type?
Old May 8, 2003 | 10:50 AM
rimpainter.com's Avatar
Question 96 4Runner MT fluid qty and type?
I posted in the maintenance section, but no replies (and I am impatient).
I did a search, and only found info on an Auto tranny from Jalaber's site.
Anybody know the exact qty in quarts for the 5 speed?
What type, 75W-90? (I want to go with Amsoil MTL)
Please help if you can. Thanks guys.
Old May 8, 2003 | 10:52 AM
SLC Punk's Avatar
When I changed my dad's tranny fluid, I think I used around 4.5-5 quarts.
I just used a generic 75-90 gear oil
Old May 8, 2003 | 01:25 PM
skoal's Avatar
oil qt
Manual transmission (drain and refill)
4 cyl - 2.7 qts
3.0 v6 - 3.2 qts
3.4 v6 - 2wd - 2.7 qts
4wd - 2.3 qts
The dealer gave me Castrol 80 90w
Old May 8, 2003 | 01:26 PM
Thanks skoal. I wonder why the 4WD man is less than the 2WD?
Anyone know?
Hey 1000 posts!
Old May 8, 2003 | 02:13 PM
SLC Punk's Avatar
Yep skoal is right, I forgot that I changed his diff fluid at the same time.
Old May 8, 2003 | 02:16 PM
NCSU-4runner's Avatar
how often should you change the diff fluid? and should i do it more often since i offroad alot now? And how difficult is it to do?
Old May 8, 2003 | 02:24 PM
Sucellus's Avatar
Cool
Ahem....
According to the Haynes Manual:
Manual Transmission Lubricant: API GL-4 or GL-5 SAE75W-90 gear oil.
Front diff: API GL-5 SAE 75W-90 hypoid gear oil
Rear diff above 0 deg F: API GL-5 SAE 90 hypoid gear oil
Rear diff below 0 deg F: API GL-5 SAE 80w-90 hypoid gear oil
I don't know what the API spec is but thought you might want to look for it.
I would hazard to guess that there are more gears in the 4wd and thus less room for lubricant?...
Old May 8, 2003 | 02:35 PM
Erich_870's Avatar
I was thinking of changing my MT fluid too (87 Runner) when I asked the guy at Napa - I know, I know :pat: - he asked me if I was "gunna drop the pan". What the heck? Drop what pan, I was going to unscrew the drain plug! He said if I just dropped the pan I would get very little of the old fluid out and that I should go some place and have them flush it. I don't want to pay $80+!! Does he have any clue what he's talking about? I was reading through my Chilton, and there is no pan, but did he mean plug? Ok I'm begining to ramble.
My questions are, can I just take out the drain plug and refill? And can I refill with Amisol brand, or is mixing possible non-syntho with syntho a no-no
Anyway, thanks for some guildance
Old May 8, 2003 | 02:38 PM
Dude, that guy is
Yes, you just drain and fill. Dont forget the drain and fill plug washers from the dealer.
Old May 8, 2003 | 02:44 PM
Erich_870's Avatar
Figures... So any problems refilling with Amisol brand if it could have been filled with non-syntho before. I have never changed since I got it so I don't know
Thanks
Old May 8, 2003 | 02:48 PM
No problems. I am in the same boat. I am going with Amsoil, but I have done lots of Manual Trans changes, just not on my "new" 96.
Go for it! Now I just have to get some Amsoil...
smthwsn357
May 1, 2024 07:28 AM
Eggslinger
Jun 8, 2019 03:32 PM
mengquis
Jul 13, 2015 10:39 AM
Rkellerman
Jul 12, 2015 08:42 AM
Poncho0206
Jul 10, 2015 06:21 PM
