96 4runner 15mpg? what are you getting to the tank?
Old Sep 24, 2008 | 05:26 PM
crolison's Avatar
Originally Posted by Greg_Canada
slowest one they made
I beg to differ on that
Old Sep 24, 2008 | 05:43 PM
racermp's Avatar
ha ok so on sat, i will change oil, fuel filter, pcv, sparkies, diff fluid, ummm i guess that covers tuneup lol
Old Sep 24, 2008 | 06:11 PM
Ian Rogers's Avatar
I got 324 on 15.6 gal last week, but I am running trd sc, urd 7th, dt headers/catback, 2.2" pulley,
Old Sep 24, 2008 | 06:52 PM
habanero's Avatar
I've kept track on fueleconomy.gov and am averaging 18 over the past 2 years.
96 3.4 manual 4x4 181412 miles 265/70R16's, always loaded down with stuff.
Tire pressure and clean air filter make the biggest difference for me.
Old Sep 24, 2008 | 08:13 PM
  #25
hotlavaaaa's Avatar
Originally Posted by racermp
yea i'm gonna try workin on it on sat. do we have plug wires? i thought we had coil packs on each plug
There are 3 coil packs on the left side of the engine and each one has a wire connecting it to a plug on the other bank of cylinders. It's a waste spark system so each coil pack fires two plugs at once. So it's 3 wires. Like was said above make sure you get either NGK or Denso dual electrode plugs.
Old Sep 24, 2008 | 08:27 PM
  #26
racermp's Avatar
thanks alot man, i'll change all of it out. thanks all for all the good info
Old Sep 24, 2008 | 08:39 PM
  #27
wormhole's Avatar
Jus drive downhill. That should help some (got 26 mpg on a tank between Ouray,Co and Montezuma Creek, Utah).
Old Sep 24, 2008 | 10:18 PM
  #28
SoCalPaul's Avatar
Just did the fuel filter & plugs. My filter was probably OK, the plugs on the driver side were just finger tight. My highly calibrated SOTP meter (seat of the pants) thinks the performance is marginally but noticeably improved. Having long extensions is a big help, I bought some "wobble" extensions from Sears & was extremely pleased I did so.
Good luck,
Paul
Old Sep 24, 2008 | 10:23 PM
  #29
Mic09dcsm's Avatar
That's pretty bad, I almost get that with 35's, a good amount of lift and stock gears, but you can call me Ms. Daisy.
Old Sep 25, 2008 | 06:37 AM
  #30
Kerby J's Avatar
wow man i feel bad for ya ive got 4" of lift 33" tires and steel front and rear bumpers and a roofrack and im getin 20mpg the main thing is the plugs and wires then the air intake then the oil changes
Old Sep 25, 2008 | 06:49 AM
  #31
4Runner202020's Avatar
i got 4in susp. lift and 2in body lift and 35's on stock gears and can pull the rare 17mpg...
bobby
Old Sep 25, 2008 | 11:05 AM
  #32
97ltd4x4's Avatar
With that kind of milage,I would replace the O2 sensor as well(the front one,B1,S1,for the parts guys)...between the cat and the engine,put in sensor then pull the 15amp efi fuse to reset fuel trim.....
unless it is running bad(plugs,compression,ect),tires underinflated,torque converter lock-up not engaging..I see no reason that you are not getting 18-22 highway,especially with a 2WD.
I get right at 20mpg on highway,with about 500 pounds of gear in the back on a 97 4wd.
Eggslinger
Jun 8, 2019 03:32 PM
Doug4320
Mar 24, 2018 10:11 PM
Tyler Cunningham
Jul 11, 2015 10:18 AM
Poncho0206
Jul 10, 2015 06:21 PM
skoti89
Jul 8, 2015 12:05 AM
