95.5 coma, no start, no codes, cel wont flash
Old Nov 15, 2012 | 04:28 PM
crash_x's Avatar
Hi all,
I have a 6/95 tacoma. (in a coma) 4 cyl, 2wd, auto, OBD2.
It came to me as a no start. (drove to work and never started again).
cel is on.
couldnt get the cel to flash with a jumper.
have spark,
have fuel,
bought a nice Innova scanner,
it came on as soon as it was plugged into the obd conn under dash. but it couldnt get any info from ecu.
no ID, no codes, no vin.
checked voltages at both obd and oem conn. all ok.
still no cel flash, just solid on.
ECU had water damage on case, but inside looked fine, had ECU rebuilt
installed re done ecu and have the same results.
cel on, wont flash.
have fuel and spark.
scanner boots up when plugged into obd2 and oem conn. but gets no info from ecu.
I think I covered most checks going through this, but Im missing some thing .
Thanks, ken
Old Nov 15, 2012 | 04:42 PM
westjohns yota's Avatar
if the ecu isnt putting codes out then it doesnt seem to be working, have you tried a junkyard ecu to see if you can get it on?
Old Nov 15, 2012 | 04:58 PM
crash_x's Avatar
truck is about 30 min away, so testing is a pain.
I could use some pinouts, flow charts, and diagrams if any one has them.
Old Nov 15, 2012 | 05:20 PM
BigBallsMcFalls's Avatar
pay some small monies and download all that, and everything about that truck
from techinfo.toyota.com. pretty sure someone here has it already too....
Old Nov 15, 2012 | 05:41 PM
crash_x's Avatar
to poor to pay, that and its a friends truck,
its costing me enough as it is
thanks anyway
Old Nov 15, 2012 | 06:56 PM
Mitchell12's Avatar
Why hello there Ken.
You can trust the answers you get here much more than that other forum we are on... it's kinda a social club at best.
Old Nov 15, 2012 | 07:53 PM
crash_x's Avatar
Smile
Hi Mitchell,
good to hear that.
I have posted this on a few forums, so I dont always know where I am.
just waiting on some returns then when I have enough to work with, I will go out to the truck
Old Nov 16, 2012 | 10:39 AM
crash_x's Avatar
hey all, I could sure use some tech info!!!
Old Nov 16, 2012 | 12:16 PM
Mitchell12's Avatar
I'm sure there's got to be a Junk yard near you. I'd try and find another ECU just to try. Otherwise you could be chasing non existent problems all over the place. Because if you're getting spark and have fuel pressure it should at the very least stumble and cough or do something when you crank it. The only excuse is that for some reason the injectors aren't firing. Sounds like your ECU is getting power but is fried still even after that rebuild.
I think you're not getting any more answers since that's really just about all you can do unfortunately.
Could always swap your rolla's engine into it
Old Nov 16, 2012 | 01:58 PM
crash_x's Avatar
nearest good yard is like 1 1/2 hours from me. im up in the hills so I have to go down to the valley.
it does kind of try to fire. its not just flat cranking. but its no more then a cough every few rev.
LOL put mine in there.it would be a waste, the truck wouldnt do the thing i do in it
Old Nov 16, 2012 | 02:00 PM
crash_x's Avatar
i need some info to go test with, then i will go out there and poke around till i fix it
smthwsn357
May 1, 2024 07:28 AM
smiley52
Jul 11, 2015 05:16 AM
Roger Borba II
Jul 9, 2015 05:05 PM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
Jnkml
Jul 6, 2015 01:20 PM
