89 V6 4Runner is slow.
Old Jul 19, 2005 | 07:35 PM
wonderwagon's Avatar
I have an 1989 4Runner V6 that is just SLOW!
I am wondering why this is, as compression is good on all cylinders (~140 psi)
Towing a 2200 lb. trailer felt the same as towing nothing, but it's acceleration is slow. My 89 V6 pickup was nowhere near this slow, so it's not just because it's the V6.
Any ideas?
Old Jul 19, 2005 | 07:39 PM
rocket's Avatar
Welcome to the forum. Its called "3.slow" for a reason.
Old Jul 19, 2005 | 07:46 PM
I don't get why people call it the V-slow, since my 89 2wd V6 pickup had awesome acceleration and lots of get-up-and-go power that my 4runner doesn't have.
Old Jul 19, 2005 | 08:10 PM
Cebby's Avatar
The 4Runner is a good bit heavier than a pickup. Especially 4WD vs. 2WD too.
Old Jul 19, 2005 | 08:17 PM
DudeBud's Avatar
not sure but 140psi a hole sounds low mine is pushing just over 200psi a hole had to take the heads down a bit to get them flat agian but not much
kyle_22r's Avatar
my 22R powered 2wd pickup could take all kinds of cars in a race. for the most part i wouldn't even attempt something like that with my 4x4.
Old Jul 19, 2005 | 08:23 PM
what does the repair manual say the compression should be?
Old Jul 19, 2005 | 09:20 PM
justanother4x4's Avatar
my 88 truck with the v6 is not quite slow, its no drag racer but it sure will smoke the tires all the way thru first gear and chirp second. fun stuff
sorry to hi jack but any idea what gears came stock in toy 4x4 v6 axle?
Old Jul 19, 2005 | 09:30 PM
Cebby's Avatar
Look at the sticker in your door jamb.
Old Jul 19, 2005 | 09:55 PM
Morphine's Avatar
Compression
wonderwagon - according to my haynes manual, for the v6 engine, 3vze your compression should be as follows:
Compression pressure at 300rpm
Standard 171psi
Minimum 142psi
Max difference between cylinders 14psi
hope this helps.
-=Morphine=-
Old Jul 21, 2005 | 11:50 AM
Silver_Truck's Avatar
The v6 2wd reg cab manual pickup was the fastet vehicle toyota made from 89-93 or so behind the supras, Mr2s and celicas...i've got a v6 4wd and its a complete slug compared to my dads 86 22re 2wd
Old Jul 25, 2005 | 03:11 PM
morphine I think you are right. THANKS for the facts I believe the 4runner is just worn out and dying. I dont believe in that V slow excuse!
Flying91
45
Apr 11, 2024 04:39 PM
icentropy
Sep 16, 2020 02:47 PM
coreyedwards7611
Jan 16, 2016 06:38 PM
BeMiceElf
Oct 10, 2015 09:40 PM
Poppie51
Jul 16, 2015 06:16 PM
