89 4runner code 52
Old Aug 29, 2004 | 08:12 PM
tcollins's Avatar
89 4runner code 52
Hi,
I am new here. Have a question: I just installed a rebuilt 22R-E in my 89 4Runner. It runs ok at idle but after about 30 seconds of driving I get a check engine light and the engine begins to run a little worse. The flash code is 52. I don't have an owners manual so i can't look it up. Anyone seen this on a first Gen?
Thanks in advance-
Tcollins
Old Aug 29, 2004 | 08:33 PM
SoCal4Running's Avatar
Knock sensor, its to the rear of the oil filter. Check the wire connection and hope that its cause to things are EXPENSIVE .
Old Aug 29, 2004 | 08:37 PM
tcollins's Avatar
Thanks! I have the old one still on the orginal engine. I'll swap it out to see if that fixes it.
thanks!
TC
Old Aug 29, 2004 | 08:52 PM
It doesnt necessarly mean the sensor is bad. It can be set off by noisy valves than need adjusting, pistons knock, ect.
Old Aug 29, 2004 | 09:10 PM
tcollins's Avatar
Valves are set to spec and engine runs quiet. We'll swap out the sensors and see what happens. I also had a struggle installing the starter so maybe I just knocked the wire off. That would be an easy fix!
Thanks again-
TC
Old Aug 30, 2004 | 04:35 PM
Kool, the plug on mine is messed up and fall off everyonce in a while.
Old Aug 31, 2004 | 07:06 PM
tcollins's Avatar
Swapped out the Knock sensor and it did the trick. The one I changed out had a differnt shape to it where I screws in.
Thanks for the help!
TC
Old Sep 2, 2004 | 04:52 PM
Sweet, glad it worked.
smthwsn357
May 1, 2024 07:28 AM
Jdgarrison
Oct 1, 2015 05:22 PM
smiley52
Jul 11, 2015 05:16 AM
Roger Borba II
Jul 9, 2015 05:05 PM
Jnkml
Jul 6, 2015 01:20 PM
