4Runner dying, should I fix?
Old Dec 12, 2013 | 12:46 PM
JHupp's Avatar
So my 4runner looks like it has a valve that is going. The truck has a misfire in cylinder 2 and all of the other cylinders have about 160 psi compression. Cylinder 2 has 120 psi. My mechanic and I are fairly certain it's a valve. I was quoted $3,000 to fix or $5,000 to put a new motor in it.
The truck is a 2001 Sport with 155,000 miles. Everything else is great on the truck and I like it a lot. I guess I'm just questioning whether or not I should put the money into it or what I can get out of it the way it sits. I have other trucks and just use this one to run around town in. What do you think guys??? Thanks!!
Old Dec 12, 2013 | 01:32 PM
94 Newbie's Avatar
Question 5K for a brand new motor ?
If used, seems high to me .
At any rate, if you like the truck, and all else is good on it, then 5K is still probably cheaper than what buying a different one would run.
I would also look at a second opinion as IIRC a head gasket job on a 1FZ-FE 6 cylinder Land Cruiser is a ~ 2K job - I have a hard time seeing where a 4 cylinder, or a 6 cylinder, would be another grand.
Just some quick off the cuff thoughts - good luck !
Britt
Old Dec 12, 2013 | 01:38 PM
JHupp's Avatar
Thanks for the heads up. I'm seeing some posts on these motors going to 300k. I guess what I'm wondering is if I do a new head on it am I realistically going to see another 100k miles out of it or is something else just waiting to break?
Like I said, I've had no issues so far and there are no leaks. Up until now it drives like the day I bought it 9 years ago.
Old Dec 12, 2013 | 01:47 PM
Stetson_md's Avatar
Yea somthing else will probably break in another 25k or so and then probably 50k after that. But what's cheaper a few hundred here and there for repairs or 30 thousand for a new pos that's going to bust in the same amount of time
Old Dec 14, 2013 | 04:44 AM
JHupp's Avatar
FYI in case anyone is in need of a vehicle in NJ
http://cnj.craigslist.org/cto/4243120909.html
Feel free to make an offer if from YotaTech.
Old Dec 14, 2013 | 06:00 AM
Team420's Avatar
The lower end is now used to lower compression, and as a result of the low compression, I'm willing to bet not all the fuel is being burnt, meaning theres prolly some getting into the lower end and washing it out. Oil smell a bit like gas?
Anyway... if you put a new head on, or fix the one you got, it will raise the compression, and likely put more strain on the lower end, causing issues in the future...
Full rebuild, or swap is what I'd do....
Old Dec 14, 2013 | 09:35 AM
Bigblock's Avatar
The valve is not burnt,YET. take a feeler gauge and check all four valve lash on #2 cyl. Both ex valves will be zero or less.LOL ! Just fin a thinner shim and drive. You can do this with the heads on the engine.Maybe $100 buck fix.
Old Dec 30, 2013 | 09:01 AM
Potomacduck's Avatar
One bad valve? Install a new engine? Five grand?
Find a new mechanic.......get a rebuilt head and drive her for another 100,000 miles. Not a big deal.
Old Jan 10, 2014 | 11:53 AM
JBurt's Avatar
You might give this a shot. Could work really well. I didn't run water through the engine but the marvel oil and seafoam worked well for me.
Charecter1
Nov 6, 2023 10:08 AM
ashersullivan88yota
Jan 18, 2022 05:37 PM
icentropy
Sep 16, 2020 02:47 PM
smiley52
Jul 11, 2015 05:16 AM
ptb12
Jul 5, 2015 01:49 PM
