4Runner is doing something strange.. Some help
Old Oct 28, 2003 | 03:52 PM
Mulkey's Avatar
Question 4Runner is doing something strange.. Some help
I have done several searches but nothing has come up that resembled this problem. I have a 2000 4Runner with a SC on it. It has 54K miles on it. When I am cruising at 1500-1900 rpm (45-60) and let off the gas a little the Yota jumps a little and drops some RPMs. When on the gas, never a problem just letting off the gas at 45-60 mph's. Does this sound familiar to anyone? Any ideas? Thanks for the help.
Old Oct 28, 2003 | 04:25 PM
4Legz's Avatar
is it a automatic or manual?
Old Oct 28, 2003 | 04:47 PM
Mulkey's Avatar
It's an automatic.
Old Oct 28, 2003 | 08:51 PM
Plays_with_Toys's Avatar
From what I have read this comes up often. I belive its the fly wheel disengaging, or is it engaging? Anyway, its the flywheel and is perfectly normal.
Old Oct 29, 2003 | 07:36 PM
Mulkey's Avatar
It drops about 400-500 rpm and then feels like it catches and back to normal. It also does it when pressing the gas barely while coasting. It is hard to explain over a computer. Also, it didn't do this when I first bought it. It just seems weird that this would be normal.
Old Oct 30, 2003 | 06:02 AM
If I remember right, when you are coasting/ cruising at higher speeds, the inertia of the tires and transmission is enough to keep the car going. So the transmission unlocks from the flywheel so that it is less strain on the motor. When you go back to accelerate the flywheel and transmission have to match speeds, so thats probably where the jolt/drop in RPM comes from.
Old Oct 30, 2003 | 06:25 AM
Mulkey's Avatar
Thanks for the help but it just seems strange. This seems like it would put a lot of pressure on the transmission.
Old Oct 30, 2003 | 06:30 AM
AFRunner's Avatar
I think hes meaning to say torque converter, but it does sound like it. I don't know what would be making it lock and unlock so abruptly though. Possibly someone else w/ the sc can tell you if that is normal. You might want to look into getting a trans cooler if the converter is spending a lot of time unlocked as this creates butt-loads of heat.
Aaron
Old Oct 30, 2003 | 06:36 AM
Oops, yeah, torque converter. I was hoping someone else would step in and help me. I don't know automatics too well, I stick to manuals if at all possible.
Old Oct 30, 2003 | 01:16 PM
Mulkey's Avatar
AFRunner- It has a transmission cooler. The only way to not feel the light "jump" is never let off the gas. When the ECT is on, you can't feel the "jump" as much. The 60K mile check-up is coming up and I will have all the fluid flushed but with all the stealership BS, I hope they do it correctly.
Old Oct 30, 2003 | 02:29 PM
AFRunner's Avatar
It should lock up at some point and time even if you never get off the gas. Generally when accelerating it will unlock, and when you are maintaining speed it will lock.
Flying91
45
Apr 11, 2024 04:39 PM
icentropy
Sep 16, 2020 02:47 PM
BeMiceElf
Oct 10, 2015 09:40 PM
Poppie51
Jul 23, 2015 05:03 PM
Poppie51
Jul 16, 2015 06:16 PM
