4 wheel drive problem?????
Old Mar 2, 2003 | 06:24 PM
knemo77's Avatar
my friend has a 95 4runner limited v6 and his 4 wheel drive will not engage. nothing..... any ideas for easy fixes or will this one cost a arm and leg?? my friends only here for the night so quick responses would be appreciated...thanks in advance.
Old Mar 2, 2003 | 06:30 PM
Skydigger's Avatar
read me!
Old Mar 2, 2003 | 06:33 PM
Corey's Avatar
Co-Founder/Administrator
I can think of a few things.
One, can he pull the lever back into 4WD?
If not, the linkage underneath could be binding on something.
If he can pull the lever and the dash light is not coming on, perhaps a VAC hose got knocked off of the ADD actuator sleeve that engages the CVs up front.
Download the factory manual for the 2nd gens here.
http://www.net-impress.com/4runner/cd/
You can get the whole thing with the big Zip file.
It might be the transfer case PDF, I am not sure.
Old Mar 3, 2003 | 10:05 AM
rpeAMP's Avatar
If the shifter works, tell him to pull off the skid plate under the engine and check to see if the white connector on the front diff is connected. If it is, then make sure that there's no corrosion, etc.
Old Mar 3, 2003 | 10:09 AM
Los Gatos?'s Avatar
When I had trouble engaging 4low it was the little rods that actually move the shizzle that makes it engage, take it to a garage and have them check out the actual linkage.
Old Mar 14, 2003 | 09:17 AM
MattM1215's Avatar
My 4Wheel drive is not working at all either. The light comes on but I was going up a steep hill and my front tires were not spinning or moving at all, both in 4hi and 4low. Any suggestions?
Matt
Old Mar 14, 2003 | 11:55 AM
Salue's Avatar
Could you give some more info. on your vehicle? Year, model, manual hubs, ADD, Auto hubs? Then maybe we can help a little better.
Salue
Old Mar 14, 2003 | 12:07 PM
MattM1215's Avatar
It is a 92' 4Runner SR5 with ADD.
- Matt
Old Mar 14, 2003 | 12:17 PM
Salue's Avatar
Have you first tried the suggestions from the earlier posts? If you're positive you don't have 4WD then you might want to check the vacuum hoses that go to the actuator. Maybe they came loose.
Salue
Old Feb 24, 2004 | 08:07 AM
AbramHart's Avatar
My system has the ADD setup. You can put it into 4 low and it seems to work fine. If you put it in 4 high the front tires lock up"they will not turn" Do you have any sugestions on this?
Old Feb 24, 2004 | 08:43 AM
MTL_4runner's Avatar
Yikes!!!
Something is seriously binding while not fully engaged
Jun 1, 2021 01:51 PM
Avenged
Jul 9, 2015 07:55 AM
colinmil
Jul 6, 2015 04:03 PM
Jnkml
Jul 6, 2015 01:20 PM
wilbertd
Jul 6, 2015 07:39 AM
