4.0 V6
Old Sep 11, 2004 | 05:56 PM
Gadget's Avatar
4.0 V6
Does anyone have a picture of the 4.0 V6 with that plastic cover removed from the engine?
Gadget
Old Sep 11, 2004 | 06:00 PM
FirstToy's Avatar
I can take one tomorrow if no one does. It's not pretty, just the intake plastic stuff- kinda anonymous looking
Old Sep 11, 2004 | 06:11 PM
Gadget's Avatar
Thanks!
Old Sep 12, 2004 | 08:53 AM
FirstToy's Avatar
Here you go
here I'm holding the cover up- you can see the oil filter next to the fill.
Old Sep 12, 2004 | 08:58 AM
Vato Loco's Avatar
Old Sep 12, 2004 | 09:38 AM
Gadget's Avatar
I can see why Toyota wants to cover that thing up. Looks like ALIEN III.
Where is the MAF sensor?
Thanks for the pictures!!
Gadget
Old Sep 12, 2004 | 09:46 AM
FirstToy's Avatar
I think it's on the side of the air filter box (that big rectangular box over on the left)
Old Sep 12, 2004 | 10:09 AM
Birdman's Avatar
Is that the oil filter I see there on the top left side of the head? Talk about convenient.
Old Sep 12, 2004 | 10:19 AM
Gadget's Avatar
I have seen the filter on the trucks I test drove.
The little thing that catches the spilled oil when the filter is removed, where does that drain to?
Gadget
Old Sep 12, 2004 | 11:43 AM
tenfourtyeight's Avatar
Gadget
There is just a hole at the bottom. When I do oil changes on them at work, I hold a plastic cup underneath so it doesn't drain onto the skid plate.
Old Sep 12, 2004 | 03:05 PM
FirstToy's Avatar
You put a length of plastic tube on it and the oil drains directly into your oil disposal container. (you can leave it plugged and just wipe out the catch dish- not a whole lot of oil drips out if you're a bit careful)
I have the oil change machine (german unit, griots) so I have never used the drain plug on my truck- never gone under it for an oil change. It makes it stupid-easy.
Gadget
Old Sep 12, 2004 | 03:20 PM
AUJWE
Guest
Posts: n/a
That Griot's machine is pretty neat. It gets just as much oil out as by draining it via the plug? Looks convenient.
Old Sep 12, 2004 | 06:15 PM
FirstToy's Avatar
Yes, it's very nice unit. The drain tube goes down to the bottom of the oilpan. It's a 4 liter engine but I usually get about 5 liters of oil out.
edit: btw, you don't have to remove the engine cover to change the oil- it helps if you need room to get at a really stubborn filter otherwise, no.
Old Sep 12, 2004 | 06:33 PM
AUJWE
Guest
Posts: n/a
I may have to look into that unit when I'm done with school and I am living somewhere that I can change my oil. Wouldn't do me much good right now. I saw on the website they said it could be used for other things too.
Even though the oil filter on the 3.4 is a PITA to get off I think this machine would still help a lot.
Old Sep 12, 2004 | 11:42 PM
EDGE's Avatar
FirstToy is that what M1 looks like with 10k on it
Old Sep 13, 2004 | 12:34 AM
FirstToy's Avatar
That was the original oil when I first changed it.
Old Sep 13, 2004 | 06:54 AM
corvettelvr73's Avatar
Where can you get pne of those german oil pumps from?
How much?
Old Sep 13, 2004 | 01:11 PM
Gadget's Avatar
Those things are slick, but using the drain plug also flushes stuff out of the bottom of the pan. So, I would still use the drain plug method every once and a while.
Gadget
Old Sep 13, 2004 | 01:23 PM
FirstToy's Avatar
Gadget
Never! That plug is going the duration!
AndYota
Aug 10, 2015 09:19 AM
stormin94
Engine Swaps
32
May 12, 2008 02:59 PM
millertime_t1
Jan 23, 2008 07:49 AM
millertime_t1
Jan 29, 2007 11:48 AM
marko3xl3
14
Nov 28, 2006 05:18 PM
