View Poll Results: What front suspension are you running?
Stock
108
34.84%
Old Man Emu Coils
51
16.45%
Stock With Spacer
48
15.48%
Bling Coilovers
54
17.42%
Tundra Coils w/ Spacer
49
15.81%
Voters: 310. You may not vote on this poll
3rd Gen/Tacoma Front Lift Rollcall!
Old Oct 16, 2006 | 11:05 AM
  #81
xcmountain80's Avatar
Thankd Bama for my options hmmmm lets see yes sas would be cool but not my cup of tea thats what my International Scout is for, yes yes I see it now limiting straps it is!!! Cause as I'm figuring it a set of cv's would be slightly more than straps. And no Steve I know you wouldnt sell anyone something they didnt need , so hard to pass sarcasm within text.
Aaron
Old Oct 18, 2006 | 08:05 PM
  #82
toy96ota's Avatar
I too am running the pp springs with hd bilstiens. they brought my runner up about 1.5"s above stock. actual lift for my runner was 3.5" in front and 5" in the rear. yeah the old springs were toast. I am considering adding 1" or 2" spacers next with a diff drop kit of course to save the cv's.
Old Oct 19, 2006 | 09:17 AM
  #83
5" huh? what is in the rear? and whats a pp spring?
Aaron
Old Oct 19, 2006 | 09:24 AM
  #84
neliconcept's Avatar
PP springs are 1 inch lift springs.. id do an OME lift before I did PP springs
http://www.performanceproducts.com/p...h+Lift+Springs
mated with bilstein hd shocks
Old Oct 19, 2006 | 10:46 AM
  #85
right right sorry
Aaron
Old Oct 19, 2006 | 11:37 AM
  #86
d0ubledown's Avatar
im running fagtech basics. havent run anything else, so nothing to compare to. theyre somewhat stiff i suppose...but the suspension has worked well for me thus far. the stiffness seems to match well with my ome890+procomp shocks outback. with the wabfab's disconnected, i get better independent travel. only thing holding me back front end performance wise is lack of a front locker.
once im ready for new front suspension, ill try out the trd tundra setup. hopefully i can just skip that step and go solid up front.
Old Oct 19, 2006 | 12:24 PM
  #87
gpcollen1's Avatar
Stock with KYB shocks - PP springs in the garage for getting ready.
Old Oct 24, 2006 | 11:33 AM
  #88
Speaking of Fabtech My brothers 6" system just fell out on the drivers side while he was just driving along.
http://s36.photobucket.com/albums/e3...ntain/Carnage/
Old Oct 25, 2006 | 10:11 AM
  #89
goldtaco9's Avatar
OME - no complaints
Old Oct 25, 2006 | 03:42 PM
  #90
jrock's Avatar
total choas-long travel-12 in. articulation
king coilovers, not a bad way to go to run our socal deserts!
Old Oct 25, 2006 | 05:29 PM
  #91
Is it bad when this happens?
Aaron
Old Oct 25, 2006 | 05:37 PM
  #92
bamachem's Avatar
naaaah, that'll buff right out. just use some duct tape to put the wheel back on when you're done and you'll be good to go.
care to tell the story? looks to me like you lost all the bolts in the lower ball joint, then the spindle jumped off, the tire went back into the firewall, where it promptly bent the fender, snapped off the upper ball joint, but not before jamming the upper arm into the upper shock mount as it bent it to hell and back.
correct?
also, if that is what happened, that's what they make blue & red locktite for...
i'm just glad you weren't hurt...
Old Oct 25, 2006 | 05:45 PM
  #93
sschaefer3's Avatar
You know what is freaking scary, besides, me. My upper ball joints were seconds away from that when they were removed for the Dana 44.
It was not the pin that was going, but the ball was pulling out of the base. Big time.
If you wheel IFS, and IFS works fine, just be sure to be up on your maintenance and inspections.
Old Oct 25, 2006 | 05:47 PM
  #94
bamachem's Avatar
look at that upper arm steve, that wasn't an upper joint failure. that was a lower joint disconnect while driving, bending the upper arm after the tire was dragged backwards. that's the only way that i can see that upper arm being bent like that.
Old Oct 25, 2006 | 06:14 PM
  #95
I knew you 2 would love those pics. If you have a brother then you might understand unless of course your the wilder of the two. Supposedly he was just driving along at 45 mph and hit a speed bump and the rest is history. As you pointed out Bama only 2 of the studs were snapped butable to be backed out by hand the other 2 lost somewhere. Austin just I dunno, how to tell you sometimes I wonder. He and a tech friend from 4wheelfarts did the lift came out good but he must not have stayed up on the maint. part of it. OMG what next his luck sucks but he doesnt help it any by pretending to not so smart cause thats not the case at all. Fabtech took a few looks at the pics and said there is a spacer in there they didnt supply so it wasnt covered. ˟˟˟˟ we thought so insurance is the next line up for the repair on this carnage. It breaks my heart but what can you do?
Aaron
Old Oct 26, 2006 | 12:02 PM
  #96
d0ubledown's Avatar
daaang..i never thought a burly piece of metal such as a uca can bend like that..
Old Oct 26, 2006 | 01:24 PM
  #97
Like a little byyyach.
Aaron
Old Oct 26, 2006 | 01:29 PM
  #98
sschaefer3's Avatar
I'm not encourageing it, I've done more than my share of them and don't want to do anymore. But, a Dana44 would get rid of all the broken parts...........
It's also alot easier on a Tacoma. It's alot of work an absurd amount of work, but all that broken stuff would be gone.
Old Oct 26, 2006 | 01:47 PM
  #99
Thank god he doesnt read yotatech but he would side with you as would I but in his current not so responsible state of Im a man because Im 19 crap, I know in the back of his mind its there and eventually it will be straight axled but not till shes paid for.
Aaron
Old Dec 5, 2006 | 08:44 PM
  #100
I can now say I have the tundra front. def a lot better then what I had
