3RD GEN with manual hubs?
Old Jul 15, 2003 | 08:02 PM
KING's Avatar
Does anyone in here have a 3RD GEN with manual hubs??
Old Jul 15, 2003 | 08:04 PM
sschaefer3's Avatar
Yes.
Old Jul 15, 2003 | 08:05 PM
44Runner's Avatar
I do...
Old Jul 15, 2003 | 08:07 PM
TDiddy's Avatar
And that's all two of 'em!
No, there's probably more out there, its just so cost-prohibitive.
I was just looking at the ORS kit again today, but it won't happen any time soon.
Old Jul 15, 2003 | 08:23 PM
keisur's Avatar
Same here. I look at it everyday in hopes that ORS might actually lower the price to a reasonable one for maybe a day so we can all jump in and buy one. If you ask me they are grossly (sp)over-priced. I wish I was Steve or the other guy so I would have it already. you guys got it when it was 900 didn't you? or were you lucky enough to score one as a proto?
Old Jul 15, 2003 | 08:30 PM
Cebby's Avatar
I thought Data had them too. 44Runner's cheating - with his Dana 44,
Old Jul 15, 2003 | 08:56 PM
KING's Avatar
Originally posted by sschaefer3
Yes.
Originally posted by 44Runner
I do...
Conversion or stock?
Old Jul 15, 2003 | 09:08 PM
44Runner's Avatar
Definately conversion...
Old Jul 16, 2003 | 03:45 AM
Cebby's Avatar
3rd Gens weren't available with manual hubs. Anyone who has them has converted with an ORS kit. Except for 44Runner who did a SAS using a Dana 44 solid axle.
Old Jul 16, 2003 | 07:18 AM
TDiddy's Avatar
Danny, you mave manual hubs on there?
Old Jul 16, 2003 | 10:49 AM
sschaefer3's Avatar
I got the Kit for 900. Warn hubs. My FJ-62 Land Cruser has them too, Aisin hubs which are short throw and alot nicer.
FYI- 2 Tacoma Aisin hubs are over 400 alone. The Warn kit is around 100 bucks. You can see how fast the Toyota parts add up. CV's axle shafts, etc.
Old Jul 16, 2003 | 01:46 PM
cruizin01's Avatar
No manual hubs on 3rd Gens? Is that for 4Runners only? What about the taco's
Old Jul 16, 2003 | 01:51 PM
keisur's Avatar
The kit comes with Warn hubs. That's why I was saying an 1100 price tag is way overpriced in my opinion. Warn hubs, toyota bearings, (are the shafts toyota's? I didn't think they were) so in my opinion the kit shouldn't be that expensive. If it came with the Aisin's I could understand, haha, I still couldn't justify the cost right now so I still wouldn't buy it yet. I'll have to sell a few things first. haha. oh and get my arb lockers and regear before the kit. hehe.
Old Jul 16, 2003 | 02:01 PM
sschaefer3's Avatar
If you want to try to piece one together, I can tell you want you need.
1. This is the biggest hurdle. Price the complete Tacoma manual hub spindle. Genuine Toyota is what ORS used.
You need 2 complete spindle assemblies and the brass ring nuts that screw into them.
2. Buy 2 remanufactred Tacoma manual hub axle shafts. These are more expensive than the ADD ones and will run you around $100 each. You then have to turn in your 4Runner ADD axle shafts for the core and "hope" they don't notice that they are slightly different.
3. You'll need 2 Genuine Toyota bearings. These are 70 each. $140 there.
4. 2 axle shaft end clips and the washer that fits over the splines. Figure on $15.00, the clips are 3.00 alone.
5. Warn Tacoma hub kit. Figure on $100
6. 12 studs to hold the hubs onto the spindles. May also need a gasket or two.
*** Now given that ORS makes stonger and a bit longer center axle shaft pieces. The ORS axles are better and stronger but this would be the econo way with used stock Tacoma axles. You would have the smaller Tacoma inners and not the larger 4Runner inners. ***
Old Jul 16, 2003 | 03:44 PM
keisur's Avatar
Thanks, I'm on my way to the Dollar General now for those parts.
Old Jul 16, 2003 | 04:18 PM
sschaefer3's Avatar
The spindles and brass nut things I would imagine are going to be quite expensive.
Old Jul 16, 2003 | 04:23 PM
KING's Avatar
You guys with manual hubs - do you still have the factory alloy wheels?
Old Jul 16, 2003 | 04:26 PM
cruizin01's Avatar
My tacoma had the factory alloys. They have a special center cap thats open for the manuals hubs.
Old Jul 16, 2003 | 04:32 PM
Sherpa's Avatar
Jeff the marmot has 'em you need to talk to him
Jeff the marmot has Warn manual locking hubs. He is the guy that helped Mike McCaskey (Off Road Solutions owner) develop the ORS kit. If you want to know anything about the manual hub conversion, you should ask him.
I know that he did not get an improvement in gas mileage like he had hoped, but he is still glad he did it. He has heaps of lift dialed into his 4Runner, and he keeps his hubs unlocked to reduce wear.
Hope this helps.
-Scott
Old Jul 16, 2003 | 04:41 PM
KING's Avatar
The reason I am asking is because I have a 2ND GEN. I bought some 3RD GEN rims - just like CRUZIN's rims (factory alloys)- and I was able to fit the rim perfectly on my 2ND GEN, however, when I tried to put the center cap, it didn't fit.
The way the 2ND GEN are designed, this cap won't fit. I tried forcing it, but since it's plastic, I was afriad to break it. All I need is about 3/8" more to fit in, but well, where do I get 3/8" from??
As the image shows, that gold cap at the end is the problem.
VICTOR, from these forums, told me I can buy the cap that will fit, which went with the manual hub, but I don't have manual hubs, and I don't want that hole in the middle.
Are there any other options??
