3rd Gen Auto Tranny Code Number
Old Jul 11, 2003 | 05:26 PM
Cebby's Avatar
I came across a cross reference with all of the Toyota automatic transmission codes. It is showing the same code for the 2nd Gen and 3rd Gen Runner's auto tranny (A340) Can someone with a auto 3rd Gen check their door jamb for the number? If this is the case, the 3.4 swap just got a bunch easier for us 3.0 guys. Just get a 3.4, ECU, Harness and bellhousing (maybe?) and go to town.
Prolax and NC - in case you didn't know, the Supra auto tranny is also the A340. All you need is a Supra auto bellhousing to make them fit together.
Old Jul 12, 2003 | 01:53 PM
Cebby's Avatar
bump
Old Jul 12, 2003 | 02:02 PM
TDiddy's Avatar
Hey Cebby,
Here's all the #'s off mine:
VZN185L-GKPGKA
C/TR 056/FW45
A/TM A03A/A340F
Old Jul 12, 2003 | 02:22 PM
Cebby's Avatar
KEWL!!! Thanks Tom.
Looks like a 3.4 or any of the Supra motors will bolt up to my auto tranny. Runners since 88 and Supras since 86 have all used the A340 autotranny. Sure makes a swap alot more feasible.
Old Jul 12, 2003 | 02:25 PM
TDiddy's Avatar
No problem. If I end up moving back to PA, it would probably be the phila. area, but I'll have to take a road trip out your way especially if you're doing an engine swap!
Old Jul 12, 2003 | 02:45 PM
its2slo's Avatar
my neighbors 88 runner has the a340 as does my tacoma. i dont know if that means they are the same?
Old Jul 12, 2003 | 03:30 PM
Phisherman's Avatar
My code is A340E for a 2.7 2wd. Does that mean I can bolt up a 3.4 and the Supra engine?
Old Jul 12, 2003 | 04:35 PM
Cebby's Avatar
Here's what I found in my spankin' new Toyota repair manual:
A340E - Tranny for 2WD - no transfer case attached.
A340F - Tranny for 4WD - with two speed transfer case attached - electronically controlled 4WD (Push Button)
A340H - Tranny for 4WD - with two speed transfer case attached - mechanically operated 4WD (Lever)
I read somewhere that all you need to bolt up a different motor with the same tranny code is the new motor's bellhousing. If that is true, it makes the swap a bit simpler.
Old Mar 7, 2004 | 09:18 AM
RkyMtn_Toy's Avatar
Question
I searched and found this post. I was wondering if anyone has swapped their A340H with an A340F? My transfercase is bad in my A340H and the option of having a separate transfercase with the A340F would be awesome instead of the integrated one. If anyone has done this, please let me know the technical aspects that'll have to be done. I also wonder if the plugs are different or if they can be spliced and make the tranny work. Any info appreciated. Thanks.
Old Mar 7, 2004 | 11:58 AM
Cebby's Avatar
This just came up again in another thread. Here's a tech article on the swap:
http://www.4x4wire.com/toyota/tech/autocrawler/
Old Mar 7, 2004 | 02:18 PM
RkyMtn_Toy's Avatar
Thanks. Hmmm. Looks like the difficulty level is pretty high for me.....
Old Mar 7, 2004 | 03:11 PM
MTL_4runner's Avatar
I wouldn't try it unless you're a glutton for punishment.
smthwsn357
May 1, 2024 07:28 AM
Jun 1, 2021 01:51 PM
mskalmus
May 28, 2017 07:51 AM
Iceman4193
Jul 15, 2015 04:48 PM
Jnkml
Jul 6, 2015 01:20 PM
