3rd gen 4Runner and rear mounted power inverter.
Old Dec 16, 2008 | 05:20 AM
xcmountain80's Avatar
Sheesh fancy picture man you just one upped me with a diagram, very nice! Your diagram shows the rear 12v power which my fridge lives on
I have an inverter that uses a 12v plug but it doesn't draw near enough power to run some applications I have not does the wiring support the load. Like runner up said 0 or 1 Ga. wire is appropriate especially if I run my semi truck inverter which can operate power tools.
Aaron
Old Dec 16, 2008 | 05:54 AM
Rock Slide's Avatar
KZN185W, your picture is a bit deceiving. The stock power inverter is actually on the right side panel of the cargo area...not in the tailgate as the picture would lead you to believe.
For more reference, that 12v power is on the panel next to Aaron's fridge as pictured above.
Old Dec 16, 2008 | 02:53 PM
chad99's Avatar
heres where i mounted my outlets in place of the ashtray
as for my inverter its just under the seat didn't want to run the ac line very far, right now i only have electrical tape acting like a face plate but i plan on making a plastic one latter.
Old Dec 16, 2008 | 03:06 PM
RunnerUp's Avatar
Originally Posted by xcmountain80
Well I ran duals under the hood, I'm using 2 red tops and waiting on a guy on TTORA to make a dual batt. steel holder. I turned them sideway and fabbed up a temp solution.
Aaron
can you PM me a picture? i would love to have both batteries under my hood!
Old Dec 16, 2008 | 03:07 PM
  #25
RunnerUp's Avatar
Originally Posted by JC_ez
You better use a thick cable to connect your frame to the body since the frame is actually electrically isolated from the body with rubber mounts. The main battery is only grounded to the engine block and body. Both your batteries should share a common ground for best performance.
interesting, never thought of that, how would i "bring it up to code" so to speak?
Old Dec 16, 2008 | 06:28 PM
  #26
Thats purty slick!
Aaron
Old Dec 16, 2008 | 07:47 PM
  #27
desertcamper67's Avatar
Does anyone have any idea how long these inverters can last on a truck that sees a lot of washboard roads and other bumpy stuff? Would rubber mounting grommets or other type of vibration isolators provide any protection?
Old Dec 18, 2008 | 08:10 PM
  #28
Higher end units should last for some years to come, like everything else you get what you pay for.
Aaron
Old Dec 19, 2008 | 08:43 AM
  #29
98SR54RUNNER's Avatar
I have seen another install like this one, can't find it right now.
However, the guy actually took apart his inverter and used the outlets on it, and mounted them in the same place. He also took the power switch and the led on it and extended the wires and mounted the power switch on his dash in an empty switch spot.
I want to do this install like this guy did because it looks very clean, I am just worried about where to mount the unit and heat problems with mounting inside the cetner console. BTW my inverter is 750 watts, black and decker, and it comes apart very easy for a clean install.
AustinTaco
Aug 22, 2022 10:45 AM
Niameyrider
Jun 25, 2015 05:50 AM
infinityisfive
Jun 16, 2015 06:51 PM
westbound
Jun 7, 2002 03:30 PM
Gene
19
Jun 3, 2002 07:07 PM
