3.4L timing marks!!!
Old May 24, 2017 | 06:15 PM
djohn24's Avatar
Hello all, hoping for some input on this. Started to do a timing belt replacement on my 2003 3.4L Tacoma. 130,000 miles and it's had been giving a squealing sound on start up with a burning rubber smell. Pretty sure it's the water pump. Have it torn down and getting ready to remove harmonic balancer. I tried to line up the timing marks before I do that and it seems like something is off. I rotated the belt through 4 times and cant get the cam marks to line up with the crank mark. I will load pictures of both cam sprockets and where they line up and a picture of the crank dot and where it lines up in relationship to both cams. What I see tells me they are off. Maybe I am wrong? Ok, phone wont connect with my computer at the moment so, I have to do a update i guess. I will describe what it looks like for now. The cam marks on the sprockets are about the 1 o'clock position while the crank pulley notch is lined up on 0 and the dot on the crank teeth is lined up with the arrow on the block. I have made at least 4 rotations with the belt. So the cam marks should be at the 12 o'clock position if I am correct. Thanks in advance to any input you have!
Old May 24, 2017 | 08:02 PM
djohn24's Avatar
Here are the pictures of both cams/marks and crank mark
Attached Thumbnails 3.4L timing marks!!!-img_0579-1-.jpg   3.4L timing marks!!!-img_0580-1-.jpg   3.4L timing marks!!!-img_0581-1-.jpg
Old May 25, 2017 | 07:27 AM
Marc's Avatar
Sounds like the cam sprockets are off one tooth as compared to the crank marker if the crank notch is aligned with the 0 mark.
Old May 25, 2017 | 07:41 AM
75w90mantraN's Avatar
Yeah they need readjustment. One method is aligning without the idler pulley and then placing it last. The tensioner must remain locked with a key until the marks line up. Then go from there. Fun time.
Old May 25, 2017 | 08:43 AM
djohn24's Avatar
Thank you both! I bought the truck new and this is the first attempt to change the belt. 130,000. Possible it came factory this way? Or, possible it just jumped teeth? 75w90, wouldn't it be as simple as loosen the timing belt, rotate cams to 12 oclock while making sure crank spocket remains at 12 ?
Old May 25, 2017 | 08:55 AM
djohn24's Avatar
I will add, I really have driven it for the last year. Just move it around the property. Months ago when the squealing started, I could smell burning rubber in engine. wasnt coming from the ps, ac, alt belts. had to be timing belt. Wonder if that could cause belt to jump? I have noticed slight miss when it idles but real slight. been like that last couple of years. I would think where it is aligned now, it would be a much more noticeable miss.
Old May 25, 2017 | 09:30 AM
Marc's Avatar
You can loosen the timing belt but you will need to compress the tensioner,
Highly recommend this tool
Amazon Amazon
Old May 25, 2017 | 11:24 AM
^^ what Marc said.
Unless you feel like taking apart the lower timing cover by the crank and loosening the tensioner manually. I imagine you've gotten this far, it's only backtracking a few steps. The tensioner tool omits those steps (a/c bracket removal). However you do it, releasing the tensioner comes last after it's all been lined up on the sprockets. Don't mind the marks on the belt not lining up after you turn the crank through. Commonly asked.
Good job btw!
Were your suspicions confirmed on the old timing belt?
Old May 25, 2017 | 12:03 PM
djohn24's Avatar
Yes, with both of your input, suspicions are confirmed on old belt. Well, I didn't remove the lower timing cover yet. Guess I am confused on the rest. Ok, lets try this. Say I remove the old belt now the way it is aligned from pictures. Then when i am ready to install new belt...that is where i will align the cam sprockets to 12 oclock. Timing belt kit came with new tensioner with pin already in it. If you all understand what i'm asking just give me a And btw...Good job you guys!!!!
Old May 25, 2017 | 02:03 PM
You got it dj
This link helped me before, also referenced and sticky'd on the YT Toy group. Great writeup from a guru.
http://www.skjos.net/toyota/timing/timing.html
Old May 25, 2017 | 05:46 PM
Marc's Avatar
I found removing and reinstalling the tensioner to be such a pain I would leave the old one on and compress it.
Just my 2 cents.
Old Jun 6, 2017 | 12:44 PM
djohn24's Avatar
Removing tensioner was a pain! I had to take a/c compressor off then remove 4 bolts on the a/c bracket. I was able to swing the bracket up enough to remove tensioner. Happy to say...it's all back together and running great! And this time, the cam sprockets are lined up correctly!. I want to thank all of you that jumped in here and offered help. THANK YOU!!
Old Jun 6, 2017 | 05:23 PM
😊 another one for YT. Great update dj.
Old Jun 8, 2017 | 06:17 AM
aowRS's Avatar
Yep! This threw me for a loop last year when I did my timing belt job. Took a few manual crank rotations for me to realize why the marks were no longer in time...
Also used the skjos writeup - fantastic!
Andreas
Old Jun 8, 2017 | 08:56 AM
Andreas
Me too. Had to google in the middle of the job to put my concerns at ease. But it was fun to do it all...including the a/c bracket.
For me it was that crank pulley bolt. Snapped off rubber and wood methods that I thought be strong enough so I ended up getting the special service tool. I remember even trying the screwdriver wedged against the flywheel teeth and getting scared I'd break one of them off.
Power steering was a pita.
Its a humbling experience and a new perspective.
