3.4l loss of gas mileage...
Old Jun 14, 2012 | 02:20 PM
GoudyMan's Avatar
I have had a significant decrease in gas mileage for a long time. I had a really difficult time passing smog a few months ago:
-new plugs
-new cat
-new muffler
-new 02 sensor
-new air filter
-new MAF sensor
After all that work it passed smog.... barely.
15 mph - RPM 1550 CO2 14.7 HC 50 CO 0.59 NO 0
25mph - RPM 2435 CO2 14.8 HC 30 CO 0.49 NO 1
I am concerned it will not pass smog next time. I would like to get my fuel mileage back and figure out why HC is running so high. Also, I know the timing is spot on. No CEL or codes on the OBD scanner.
The move to a different state comments on smog are not helpful. Just looking for some advice to get my gas mileage back.
Old Jun 14, 2012 | 02:35 PM
donomite49's Avatar
i have felt your pain. used to live in cali...
have you thought about injector cleaner.
maybe a scan tool to check engine tune.
Old Jun 14, 2012 | 02:49 PM
GoudyMan's Avatar
did injector cleaner, seafoam and a OBD scanner. No luck.
Old Jun 14, 2012 | 03:08 PM
donomite49's Avatar
seafoam gotcha.
the scanner, my question is, can you check air fuel ratio afr to make sure ecm is not in limp mode, or in open loop with the scantool?
iirc supposed to be in open loop not the default (rich) closed loop safety mode.
Old Jun 14, 2012 | 10:00 PM
GoudyMan's Avatar
not sure what you mean by open loop and closed loop?
i do not know how to check the air fuel ratio?????
Old Jun 15, 2012 | 05:04 AM
Texas_Ace's Avatar
Try resetting the ECU, pull the EFI fuse and then turn the key to the on position a few times to drain the residual charge in the ECU.
If you use the scan tool it will have a a lot of stuff to look at, just make sure everything seems normal.
Coolant temp should be around ~180-200
Long term and short term fuel tirm is also important
It will also tell you if it is in closed loop or open loop mode (open loop is for cold starts and WOT pulls, Closed loop is for everything else. It runs a lot richer in open loop)
Old Jun 15, 2012 | 05:17 AM
rworegon's Avatar
Just the opposite is correct. A warmed up, well tuned engine should operate in closed loop mode i.e. the O2 sensors are reporting data to the ECU and the ECU is making air/fuel corrections based on conditions. When warming up and under certain other conditions i.e. WOT, the engine will run in open loop. Simply put, open loop is when the engine is least efficient in operation.
Closed loop described on page 15 and open loop on page 16:
http://www.autoshop101.com/forms/h25.pdf
Also useful:
http://www.4x4wire.com/toyota/4Runner/tech/OBDII_ECU/
Old Jun 15, 2012 | 05:25 AM
rworegon's Avatar
OP, do you have any vacuum leaks? A small crack in a hose or the intake hose causes unmetered air to enter the system and can do strange things.
New PCV valve?
What plugs were used when changed?
Have the plug wires ever been changed? How many miles on them?
Are you using any coolant?
Fuel injector issue i.e. stuck open?
High HC troubleshooting, page 2:
http://www.ncttora.com/fsm/1996/SIL/.../cohc/insp.pdf
Sleaker
Aug 26, 2020 06:03 AM
mussy01
Dec 13, 2016 08:20 PM
Tacoma1313
Aug 17, 2015 05:44 PM
nonstop
Jul 24, 2015 06:29 PM
1996Taco
Jul 20, 2015 12:02 AM
