3.4L 4Runner Brakes
Old Jul 9, 2003 | 05:42 AM
keisur's Avatar
Originally posted by 4RUNR
Are you guys just rambling or what? Autzone had Brembo OEM replacement for under $50 too. Autozone is hardly a store selling 2nd rate parts, and prices to challenge mail order too!
cough, cough, gag, gag. I'm sorry, from here it sounds like you are saying autozone is top notch, I guess I heard you correctly since anyone who really knows, knows that Autozone parts are actually closer to 5th rate, they SUCK!
Old Jul 9, 2003 | 05:46 AM
amorphous's Avatar
from autozone.com....16" wheels and me...
'fraid not, chief....at least not for 16" wheels....and they ain't Brembo...from autozone.com:
Home > Shopping > Brakes & Traction Control
Search Results: BRAKE ROTOR - FRONT
Click "Buy Online" beside the item you'd like to purchase from AutoZone.com.
Click "Add to Store List" beside the item you'd like to add to a shopping list that can be sent to and paid for at your preferred AutoZone store.
BRAKE ROTOR - FRONT for a
1998 TOYOTA TRUCK 4 RUNNER 4WD
WITH 16" WHEELS (Change)
Normal Stock
Special Order
Not Available
Item Part
No.
Warranty Core
Value Unit
Price Availability
Store Web
AIMCO
ROTOR ONLY 31204 3 MO $53.99
BRAKE_ROTOR_NOTE SEE NOTE
**SERVICES 1 WHEEL ONLY; O.E. MANUFACTURER RECOMMENDS
REPLACING IN PAIRS.
cheapest place I found Brembo's is here (just got mine YESTERDAY!):
www.thepartsbin.com
~aaron
Old Jul 9, 2003 | 05:51 AM
TOR
Autozone
Riiiight, keep thinking that. Actually they do sell 2nd rate parts I have the customers and testimony to prove it. As for challenging mail order parts, there's no challenge I sell the real deal, they don't. I wouldn't trust them with anything vital or crucial on my vehicle. I have too many customers that come in the shop after just purchasing parts from Autozone and they have broken or don't perform correctly. I am speaking from what I see everyday and what my customers tell me.
BTW, if you think you are getting a deal from these guys on your parts guess again. They have a higher mark up on their parts than the dealership does. We supply them with certain parts that there are no aftermarkets for. I have been in a few stores and seen what they retail for vs what they buy them from us for. This holds true to a lot of other products they sell in their store as well.
Todd
Old Jul 9, 2003 | 06:01 AM
Highland Runner's Avatar
I have the middle of the line rotors from Autozone that cost like $40 each. I originally bought these rotors as "temporary" as I was going to buy drilled/slotted rotors, but couldn't afford at the time. The castings look identicle the the original OEM rotors. Living in the mountains my brakes get a lot of use, and these rotors have held up well (to my suprise). I use the Perf. Fric. pads #5024.
Old Jul 9, 2003 | 06:06 AM
  #25
TOR
Autozone
Old Jul 9, 2003 | 07:06 AM
  #26
rimpainter.com's Avatar
Originally posted by keisur
The '98's don't have the LSPV's.
Weird. I wonder why every other model besides the 98 would have LPV's (aka BPV's)?
Are you sure?
Check out this and scroll down to the brake section. I just dont understand why Toyota would "skip" the 98's and put them on everything else.
*Edit* Ok, now I get it. It says the 4 cyl models have it. Hmmm. Ok, well I stand corrected for the 3.4. It just doesnt make sense to me.
Old Jul 9, 2003 | 07:17 AM
  #27
amorphous's Avatar
keep scrolling....
<96 runner> if you keep scrolling to the right you'll see this:
"Power-assisted with proportioning & bypass valve for V6/ABS equipped models"
so I think they DO have the LSP/BV.
can anyone clarify this? I need to check to see mine's in the correct length spec!
~aaron
Old Jul 9, 2003 | 07:24 AM
  #28
keisur's Avatar
Originally posted by <96 Runner>
Are you sure?
That's a mixup on our part. I was referring to a Load Sensing and Prop Valve. Mine doesn't have a load sensor, it's just a Proportioning and bypass valve. I see what you are talking about.
Old Jul 9, 2003 | 07:27 AM
  #29
amorphous's Avatar
'aight!
Ok, I'm confused. What's the difference btwn a LSP and a Proportioning Valve? does one just balance the front to rear ratio...and the other actually DOES check for the amnt of weight in the rear of the truck??
~a
Old Jul 9, 2003 | 07:33 AM
  #30
Its all good, you're wrong and I am right as usual.
Old Jul 9, 2003 | 07:37 AM
  #31
keisur's Avatar
Actually haha, you were half right and I was half right. The LSP's (aka BPV's) is not right. Load Sensing and Proportioning/Bypass Valves have the arm to sense the rearend load. The one that is in the V6 equipped runners is just a Proportioning/Bypass Valve, not the Load Sensing variety, hence the confusion on my part since I have no load sensing arm in my rear, ooh that didn't sound right.
Old Jul 9, 2003 | 07:44 AM
  #32
amorphous's Avatar
so....
where they say in the manual that you "must have final shackle adjustments performed at a reputable shop" can be ignorned? (since it has none)
All that would matter would be that the valve is functioning correctly, correct? And how would one determine that?
~ ~a
Old Jul 9, 2003 | 07:50 AM
  #33
keisur's Avatar
Re: 'aight!
~a
The LSP/BV actually checks the weight in the back via an arm that moves the valve to sense a load. the PB/V just proportions it, not sure how though, I assume it's computer controlled because of the ABS and uses the wheel speed to calculate it or something. Talking out of my again, .
Old Jul 9, 2003 | 10:28 AM
  #34
frederickg's Avatar
I got a quote from toyotaparts4u for the rotors
Rotors 43512-35210 $73.08
Is that good?
I prefer using factory parts.
If you've ever tried installing an aftermarket rear brake cylinder you might understand why I use OEM parts and just try to get the best deal possible.
After going through several of them from different vendors and wasting a lot of valuable time I ended up going to the dealership and getting one of them that worked perfect the 1st time.
This was on my 1989 4Runner.
Old Jul 9, 2003 | 10:52 AM
  #35
TOR
Rotors
The front rotors going off the part number in the previous thread would be $144.08 shipped to your front door.
Brakes: 04465-35240 $41.71 w/ shipping
Total for both would be $185.79 w/ shipping to your front door.
Todd
Old Jul 9, 2003 | 11:03 AM
  #36
frederickg's Avatar
I already ordered the TRD HP Pads through toytoaparts4u
Cost $42.95
After I take off the tires this weekend and check the rotor width I'll decide whether to have the rotors replaced.
Thanks!
Old Jul 9, 2003 | 03:36 PM
  #37
keisur's Avatar
$62.19 for a Brembo HERE
Old Jul 11, 2003 | 10:26 PM
  #38
frederickg's Avatar
Well I went to the stealership today and talked to them about ht e rear proportioning valve and when I did they looked at me like a deer in headlights. I then asked to talk with a technician who said I don't think it has one.
Anyhow to make a long story short. I got my keys back and left.
I will be installing my TRD Transmission cooler and decided I'd see what I can do about the brakes since I'm already go to be working on the vehicle.
I'll take some pictures and let you know what I find out.
Old Jul 12, 2003 | 05:44 AM
  #39
keisur's Avatar
That's the reaction I get from those guys whenever I go in and ask anything, even something like "where's the oil filter in the thing." The one guy I talked to who did my rear axle seal under waranty 3 times, and I mean the guy that actually did the work, couldn't even tell me the offset distance or tolerance on the last bearing ratainer/seal surface! and when asked if he can look it up, what does he tell me? "Uh, I don't think so." not because he wouldn't, but because he didn't know that he could! so I had to join AllDataDiy to get the offset info so I could press the abs rotora and last retainer on. long story short, I wouldn't believe all of what those dudes say. I haven't been able to locate it on mine either but I don't have a soft brake problem and bleeding the 4wheels has done a good job with mine so I haven't been inclined to search all that well for it.
ashersullivan88yota
Jan 18, 2022 05:37 PM
Jun 1, 2021 01:51 PM
87turboPA
Jul 12, 2015 07:49 AM
Jnkml
Jul 6, 2015 01:20 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
