3.4 running like crap
Old Oct 16, 2013 | 07:54 AM
Spotvangogh's Avatar
I have a 86 4runner with a 96 3.4L about 150,000km
Buried it in a puddle and it started running really rough. If I let off the gas for more than a few seconds it would stall out. And under load it would bog down.
I kept it going for a while and it was able to idle on its own but very sporadically.
Drained a ton of water out of the tank and changed plugs, wires, and hollowed out cat.
Seemed to be doing good until I took it out wheeling.
Now the rpms won’t get up very high. I don’t have a tach but I’m guessing it’s about 3k unless it’s in 4L then I can get them up. Bogs right done occasionally and it over heated just all of a sudden and started boiling out of the reservoir.
It starts and idles good right now but seems to get rough when it warms up.
Any ideas would be greatly appreciated.
Old Oct 16, 2013 | 10:47 AM
vital22re's Avatar
totally a bro
any codes?
Old Oct 16, 2013 | 10:50 AM
rworegon's Avatar
Hmmm...."buried in a puddle", you say. Did you clear any water that got into the intake and cylinders before re-starting?
Old Oct 16, 2013 | 06:25 PM
BigBluePile's Avatar
Geezus....
Old Oct 16, 2013 | 06:38 PM
Kiroshu's Avatar
I see a lot of red flags in the original posting...
-Engine compartment took on water...
Lots of electrical and mechanical items could be contaminated allowing engine performance issues.
-Water entered the fuel system...
Multiple fuel delivery items damaged and or contaminated...?
-Engine overheated...
Possible internal engine damage...
Old Oct 17, 2013 | 11:39 AM
Codes are p0300 random misfire and a code for every cylinder saying the same.
Water didn't realy get in the intake as I have a snorkel But everything under the hood did get very wet.
It does seem to idle perfect when cold but warm it runs rough and won't rev past 3k in high.. Still revs normally in low
Old Oct 17, 2013 | 11:41 AM
Also seems to be vary rich as well
Old Oct 17, 2013 | 07:45 PM
Kiroshu's Avatar
Check air intake hose(s) for damage...?
Mass Air Flow sensor..?
Air filter restricted...?
Old Oct 18, 2013 | 07:18 AM
Just took everything off to check timing and it seems to be about 100 degrees off.
What are the chances that this didn't destroy my valves or anything??
Old Oct 18, 2013 | 07:31 AM
rworegon's Avatar
3.4 5vz-fe is an non-interference engine so it did not hurt the valve train or pistons.
Can you clarity what you mean by "100 degrees off"?
Old Oct 18, 2013 | 07:41 AM
That sounds wonderful but yes it was 100 degrees off. Is there nothing that would of destroyed?
Old Oct 18, 2013 | 10:12 AM
rworegon's Avatar
Get the cams and crank aligned to their TDC marks and put the belt back on. Many threads on the topic around here.
Old Oct 19, 2013 | 12:27 AM
wyoming9's Avatar
Red face
You mean it will still run with things so far out of time??
Which says to me getting the timing belt any where near close should be just fine !!??
I would hope I missed something
Old Oct 19, 2013 | 11:54 AM
TheDurk's Avatar
And it still ran? I guess the real question is how did running through the water get the timing off? Are both cams off 100° or just one? Is the belt stripped or otherwise damaged?
The key question is did it hydrolock? The fact that it ran at all says it didn't. But that's the only way I can think of that water would skew the timing by that much. In and of itself, the timing being off will not hurt anything. But whatever force caused that to happen, may indeed have damaged something. So please explain exactly what happened to the belt, if anything, and how you figure 100°...
I would restore timing and then do a compression check. Go from there.
Old Oct 19, 2013 | 12:46 PM
tantacoma's Avatar
Not familiar with the 3.4, but my 2.7 has spark plug wells. If you have them, water might have gotten in there causing shorts. Pull the wires off, and inspect the wells.
Old Oct 19, 2013 | 07:55 PM
Just one cam was off n the belt seemed good. Got a full timing kit n now she runs like new. Thank you for all the input
Flying91
45
Apr 11, 2024 04:39 PM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
XtraCab
Apr 12, 2020 05:25 AM
Colington
Mar 8, 2020 09:51 AM
94whiterunner
Jul 12, 2015 07:15 PM
