3.0L is out, what to replace before going back in?
Old Jan 25, 2005 | 12:04 PM
Eric's Avatar
I've got a new (to me) 3.0L motor with 88,000 miles sitting on an engine stand, what should I replace on the motor before I shove it in my 1990 4runner?
I'm thinking a timing chain is manditory, but what elst should I replace while the moto is easy to work on?
also are there good online places to buy parts at good prices?
thanks
Old Jan 25, 2005 | 12:08 PM
CynicX's Avatar
i would just about replace everything if i had the money, and of course a good tune up...plugs wires etc etc
Old Jan 25, 2005 | 12:44 PM
Eric's Avatar
please elaborate on "everything"
Old Jan 25, 2005 | 01:14 PM
Keggo's Avatar
maybe check the pcv valve for any blockage, water pump... get better headers for it while you're at it!
Old Jan 25, 2005 | 01:36 PM
Bumpin' Yota's Avatar
You want to swap out the steel freeze plugs with brass ones - the steelies like to rust through. You want to ground the outer shield of the knock sensor wire ot the block somewhere.
Hell I'd pull the heads and inspect them very closely for cracks or warpage. If no issues, then I'd find some head studs and have a copper crush gasket made for the heads with the same quench distance as the OEM unit. As I understand it the rods are pretty stout in the 3vze and with a new copper HG and head studs, you've just corrected the ONLY issues this engine ever had...
I understand that larger valves and larger injectors also help too...
After that point you can do a TON of power mods due to the low CR through forced induction or if you go NA you can still put on headers.
Old Jan 25, 2005 | 01:39 PM
nunsa's Avatar
thanks
Timing Belt, the 22's have the chain. Also consider replacing the valve cover gaskets they always leak on the 3.0. Headers, Headgasket - yeah, they leak!
Knock sensor and wire, tune-up, take that crossover off and replace it, it's a power robber and a half.
www.toyotaworld.com, www.performanceparts.com, www.butlertoyota.com,
www.toyotaoemparts.com, www.truckperformance.com
Good Luck!
Old Jan 25, 2005 | 02:27 PM
oh those F!@#$%@&*())^&#$$! valve cover gaskets!!! GRRRR
I just swapped one set...
PCV valve too...
Old Jan 26, 2005 | 01:49 PM
95ToyotaPU007's Avatar
I would change the oil pan and valve cover gaskets for sure. Another thing that would suck once you got the engine back in would be leaking crankshaft seals. I would replace them too. If you're gonna stick with the stock exhaust set up, install new flange gaskets for both the manifolds and pipes.
Good Luck
Old Jan 27, 2005 | 06:45 AM
Tacotex's Avatar
I would definately replace the rear main seal
Old Jan 28, 2005 | 03:55 AM
Ilovemountains's Avatar
at least do the V cover gaskets!
I would at least change out the valve cover gaskets and cam seals. I would also change the water pump and timing belt while the engine is out of your rig. I just did all of this on my 88 and it SUCKED. When the day comes to pull my 3.0 out I will install headers. For $500 it is well worth it while the engine is out to install them now! OR you could make a custom cross over pipe turning your stock exhaust manifolds into a set of home grown headers; the cross over pipe dumping backwards up into the other side is by far the most restricted exhaust system I’ve ever seen! But at the least put the $ into a set of gaskets, timing belt and H2O pump now, and get OEM parts! Have fun, you’re lucky its out, the water pump and valve cover gasket job SUCKED, did I mention how bad it SUCKED?
Old Jan 28, 2005 | 04:37 AM
gwhayduke's Avatar
A minor rebuild might be the ticket if you have the time and a little extra money. The bottom end is probably good, with the replacement of crank seals. New waterpump, and timing belt.
Pull the heads, get 'em ported, polished and maybe over size valves. Find out how much oversize NUNSA went with his valves. Match the exhaust ports to a set of headers. Polish the intake, and match it to your heads. New head bolts and gasket. There's a new headgasket out on the market that is supposed to do a superior job on engines that are prone to headgasket failure...I'll see if I can't locate more info on it. New gaskets all through the top end. Oversize TB. And that should do it.
Old Jan 29, 2005 | 04:04 PM
Eric's Avatar
well I was hoping to not pull the heads. I'm going to do a compression and leak down test today to see If I need to or not.
I did notice that there was a pretty large amount of sludge in the intake manifold after the TB. what normally is the cause of this? EGR valve, or a leaky 7th injector?
here are some pics of the sludge
looking from the TB down the intake manifold...
also the Timing belt looked pretty good, is there any indicators to determine the age of the belt?
Old Feb 9, 2005 | 07:51 PM
Eric's Avatar
bump... motor in the truck is comming out by tomorrow night (no helping hands tonight) should have the truck running by next wed.
Is that sludge normal?
Ladythump
Jul 4, 2015 03:35 PM
rbravo1
Jun 29, 2015 01:34 PM
newzingo
Jun 24, 2015 01:50 PM
ShaunKris
Jun 17, 2015 04:33 PM
infinityisfive
Jun 16, 2015 06:51 PM
