3.0 V6 Ticking...
Old May 3, 2004 | 04:32 PM
mxracer0486's Avatar
3.0 V6 Ticking...
Alright, before I dump all my money into a lift I wanna find out if this is really bad...
When my runner is warmed up there will be this tick, its not constant as if to be injectors, its more irradic (sp?). Only does it when its warmed up, cant find the source of it though... any thoughts?
Old May 3, 2004 | 07:18 PM
Poul D'eau's Avatar
Sticky valve train? Mine used to tick but with mobil 1 and a yota oil filter, its pretty quiet.
Old May 3, 2004 | 07:39 PM
amusement's Avatar
My 3.0 @ 125K on it. When started you can ticking on a drivers side valve. The ticking stops when oil reaches the valve train. I use an additive called tufoil. Tufoil contains MOLYBDENUM DISULFIDE. There's more info located at
http://www.bobistheoilguy.com/moly.html
I am not totaly convinced Tufoil is a good addative based on cost. But, I haven't had any issues as today. I used Slick 50 and other teflon based oil additives in my Taco and ended up having major problems. Problems included starving the top end. Teflon was blocking oil inlets and channels increasing the friction on the valve train and cam.
Old May 3, 2004 | 08:15 PM
ChickenLover's Avatar
Look where your steering shaft penetrates the firewall (on the inside of the truck). The seal there might be gone. Mine was, and the ticking drove me insane. Once I replaced it the ticking stopped. It turned out to be normal engine noise just coming through the hole.
Old May 3, 2004 | 10:03 PM
Its not a normal noise, i hear it more when i stop to get out and leave it idling, it will be like tick, wait 2 secons, tick, wait 4 seconds tick, just very sparadic.
Old May 4, 2004 | 11:47 AM
ByThaBay's Avatar
my 93 3vze does exactly the same thing.. maybe its normal?
Old May 4, 2004 | 12:00 PM
AF1's Avatar
AF1
Mine does the same thing....sounds like exhaust manifold or shields are expanding....I can hear it sometimes when I drive.....
Old May 4, 2004 | 12:32 PM
I hear mine mostly when its at and idle or low rpms... i opened the hood to see if i can find it to no avail, when i shut the runner off it stops....
