3.0 Intake Mod
Old Aug 29, 2004 | 03:36 PM
Jeffires's Avatar
3.0 Intake Mod
Hey, I have a question about the air intake for my 3.0....I'm new to yotatech and I hate to start a thread that has been addressed before, but I can't seem to find what I was looking for in any old threads.
My question is- for the 3.0, what is the best mod for the air intake? I've seen where the entire bottom has been removed, but I dont want to do that because of water.
Other threads seem to say that there is not ample room for a deckplate on the 3.0.
I don't really want to spend the money on the entire K&N FIPK or whatever, but if it is the BEST way, I guess I'll $ave up.
I would appreciate anyone's input and suggestions. I have found more useful information on this site in the past few weeks than anywhere else....Thanks for any help.
Old Aug 29, 2004 | 03:44 PM
kevin444's Avatar
I dont have a 3.0 but i seen one guy on forums just drilled alot of holes into the airbox. Basically the bottom looks like a purcolator.
Old Aug 29, 2004 | 04:03 PM
humanoid's Avatar
Yeah, I think the only mod for your airbox would be to drill the $%&* out of it; making it look like a woodpecker attacked it or something. Have you checked the tech section yet on this site? Should have some great info for you, check it out.
Old Aug 29, 2004 | 04:28 PM
Corey's Avatar
Co-Founder/Administrator
Go to the Tech section and look for Blu's 3.0 ISR mod.
This mod which removes a lot of the Intake Silencer stuff has also been done by UKMyer's and another member named Marc P.
This is a common mod on both the 3.0 and 3.4 engines.
Here is member Marc P's post
https://www.yotatech.com/forums/f2/pics-my-custom-isr-mod-37786/
Old Aug 29, 2004 | 04:47 PM
Scofco's Avatar
If you are that concerned about water, then get a snorkle.
The water isn't really an issue if you drop the bottom out... if water is that high already, then the bottom of your airbox not being there isn't going to make any difference.
Old Aug 29, 2004 | 05:18 PM
Cebby's Avatar
I've been happy with my K&N FIPK, but I plan on making something custom due to some of the stuff I need to fit under the hood.
If you want some detailed pics of the FIPK installed, let me know. You can probably booty-fab something that will work and will be dirt cheap...
Old Aug 29, 2004 | 06:00 PM
MTL_4runner's Avatar
ROTFLMAO!!!
Yeah that is the general idea for sure.
Old Aug 29, 2004 | 06:05 PM
red 59's Avatar
Drilling the holes on my airbox only helped a little on my 91. My 2.7 is still faster than the old 3.0.
Old Aug 29, 2004 | 06:59 PM
Jeffires's Avatar
Thanks- I found that write up by Blu and I think i'll go get the parts tomorrow....sounds like it will be worth it
Old Aug 29, 2004 | 07:14 PM
BTOWN4RUNNER's Avatar
Is it just me, or since you drill that many holes in the box, why not just take it off? Water is going to come in anyways with the holes...
Old Aug 29, 2004 | 07:23 PM
Marc P's Avatar
I did the ISR mod that Corey posted the link to about a month ago, today i drilled holes in my airbox, changed plugs, wires, cap and rotor---my 3.slow is still slow, but runs very good.
Old Aug 29, 2004 | 09:23 PM
Jeffires's Avatar
I'm going to do the ISR mod...I think I'll hold of on drilling holes...I'd rather just take the whole bottom off. I'm on gravel roads and in the swamp a good bit, so I'm thinking twice about exposing the filter any more.
Thanks
Old Aug 30, 2004 | 12:27 AM
4RunnerKid's Avatar
My FIPK is pretty cool. I think it could be better though. I want to fab up a cold air box someday. What exactly are you going to do Cebby?
Old Aug 30, 2004 | 03:27 AM
gwhayduke's Avatar
I left my airbox alone. I'll go for a snorkle early next spring. All of the above methods let more air in, but it's air from the engine bay and it's HOT. Com'on guys...we all know hot engine air is the worst kind.
Old Aug 30, 2004 | 03:29 AM
Cebby's Avatar
You're just going to have to stay tuned...
Old Aug 30, 2004 | 04:40 AM
Marc P's Avatar
Mine is a mix now-I left the stock pipe behind the headlight and drilled about 20 holes underneath--so mine is a luke warm intake.
Jdgarrison
Oct 1, 2015 05:22 PM
Alex Bessinger
Aug 31, 2015 09:17 AM
priest16
15
Aug 6, 2015 07:43 AM
Massmayhem247
Jul 18, 2015 05:46 AM
Nickdigg
Jul 7, 2015 06:04 AM
