3.0 Cam Replacement - Advice?
Old Apr 20, 2004 | 02:47 PM
jimrockford's Avatar
Question 3.0 Cam Replacement - Advice?
I had my '91 4Runner worked on a couple of weeks ago to fix a clicking sound during acceleration. I was told the valves needed to be adjusted. When I picked it up, they said they adjusted them so they were all within specs, but found that one of the cam lobes had worn unevenly. They said that was the cause of the clicking. They recommended replacing it.
Since I need to replace it anyway, does anyone know if anyone makes a performance cam for the 3.0? Also, how much should it cost to replace and what's involved? The mechanic I took it to (independent mechanic that used to be the head mechanic at a Toyota dealership) said he'd charge about $550. That was in Oregon, though, while I was on vacation.
Old Apr 20, 2004 | 02:58 PM
CTB's Avatar
CTB
Check out DOA...I think they make one for our 3.0L.
Old Apr 20, 2004 | 03:04 PM
This looks like the place you're talking about, right:
DOA Racing
It says $275 plus the valves need to be faced at 44 degrees and valve seats at 45 degrees. What exactly does that mean and how much are we talking?
Old Apr 20, 2004 | 03:20 PM
CTB's Avatar
CTB
Ya, DOA Racing is what I was talking about, but that's all the farther I can help you on the subject...sorry.
Old Apr 20, 2004 | 06:05 PM
radrex's Avatar
Knocking during acceleration, is not a worn cam... It is probably due to cheap gas, or some kind of timing related problem. If the cam was worn down - it just wouldn't open the valve as far, causing less power etc..
bigjstang
Jun 2, 2025 03:56 PM
Charecter1
Nov 6, 2023 10:08 AM
icentropy
Sep 16, 2020 02:47 PM
skoti89
Jul 8, 2015 12:05 AM
Vargntucson
Jul 4, 2015 12:15 PM
