2nd gen trac bar/ panhard bar removal
Old Aug 4, 2005 | 07:57 AM
Y2Krunner's Avatar
i am trying to remove my trac bar or panhard bar (whichever you may like to call it) and the upper mount bolt wont seem to come out. is there a trick to getting this one out or am i missing something here? i would assume once the nut is removed the bolt should be able to come out- no such luck for me. any advice?
Old Aug 4, 2005 | 08:23 AM
geneius's Avatar
The one on the driver's or passenger's side?
Old Aug 4, 2005 | 08:31 AM
anthony1's Avatar
The driver side one, the bolt is actually part of the axle.
The passenger side one, it's been in tension all this time, so after you loosen it, put the nut back a little so you dont' ruin the thread, then hammer it till it start to back out the back end.
Old Aug 4, 2005 | 08:42 AM
94x4's Avatar
Guest
Spray with some "Rust Bust" first, then beat with hammer.
Old Aug 4, 2005 | 10:10 AM
Y2Krunner's Avatar
its the upper one- the passenger side. does this mean the bushing is shot or something? is it all fine to put back together with original hardware?
Old Aug 4, 2005 | 10:45 AM
94x4's Avatar
Guest
A visual inspection should serve to determine whether or not it's "...fine to put back together with (the) original hardware." Although most here would advocate upgrading to better/new materials whenever possible.
Old Aug 4, 2005 | 10:47 AM
Y2Krunner's Avatar
are the bushing and bolt available from toyota? does anyone know this and maybe for how much if they have replaced them before
Old Aug 4, 2005 | 10:49 AM
Robinhood150's Avatar
Bill from pennsylvannia had a hard time with this one, he ended up torching it out and having to piece together a new bushing/bolt. Search around in the off road section.
Meanwhile, us California 4runners just have to spray it with oil and tap it out.
Old Aug 4, 2005 | 11:41 AM
geneius's Avatar
I did what Bill from PA did. I cut the bolt off, then torched the crap out of the bushing till it fell out. Cleaned it up w/ a screwdriver and then using a shock bushing from Advance Auto Parts ($4.99) I trimmed it and stuck it back in. Works like a charm.
Old Aug 4, 2005 | 11:44 AM
Y2Krunner's Avatar
completely off topic now- anyone know what years i can remove the manual hubs from to do a conversion on my 92 4runner with auto hubs?
Old Aug 4, 2005 | 12:01 PM
geneius's Avatar
I don't know, but I went the easy (not cheap) way and just bought some WARN premium hubs. Didn't need to rebuild, it was simple. About 30 minutes per wheel and it looks so nice and shiny.
Old Aug 4, 2005 | 01:02 PM
anthony1's Avatar
any IFS 4runners up to 95 or IFS pickup up to 95 1/2
Old Aug 4, 2005 | 01:05 PM
leebee's Avatar
first and second gen runners except the solid axles from 84 & 85 should be interchangable. grab new gaskets from the stealer, clean up the mating faces on the hub body, cap and wheel location, check there is sufficient grease and bolt them on.
lee
Sep 4, 2015 09:27 AM
vanion2
Jul 29, 2015 06:17 PM
coffey50
Jul 28, 2015 10:55 AM
Steezy96yota
Jul 6, 2015 10:00 AM
HRDC0R19
Jul 5, 2015 06:43 PM
