WRITEUP- Changing a fuel filter on a V6 4Runner
Old Jul 3, 2004 | 01:02 AM
Bob_98SR5's Avatar
Someone had to do it, given all the recent talk about it. This was an easy one to do (and to write):
http://www.4runners.org/writeups/fuelfilter/index.html
Despite the writeup, I didn't end up changing mine out b/c I got the wrong part from the parts dealership that i ordered from (problem solved by dealer---thank you)
Enjoy,
Bob
Old Jul 6, 2004 | 03:13 AM
AznSky's Avatar
HAHAHA SUCKER!!!
So I guess saving that 10 bucks wasn't worth it huh?
hehe thanks for the write-up
Old Jul 6, 2004 | 09:09 AM
X-AWDriver's Avatar
"Honey,where the Tabasco sauce?"
"Sorry,I left it in my tool box again"
(I'm gonna try it next time)
Old Jul 6, 2004 | 09:11 AM
Bob_98SR5's Avatar
X,
Yeah, it works. I was a huge skeptic myself the first time, and though I prefer PB, I'll use the tabasco if i can't find my can of PB.
Bob
Old Jul 6, 2004 | 10:27 AM
TDiddy's Avatar
Originally Posted by Bob_98SR5
If you give it a few good shakes, more should come out.
Ummm.... oh, nevermind.
Hey Bob, do you have any plastic covering up the fuel filter? When I did mine, I had to remove a plastic shroud-faux skid plate-thing first.
Old Jul 6, 2004 | 10:34 AM
Bob_98SR5's Avatar
Tom,
Nope, no plastic shroud.
Bob
Old Jul 6, 2004 | 10:38 AM
TDiddy's Avatar
OK. I just mentioned it in case someone e-mails you and says they can't find it. They may need to remove that plastic piece, but hopefully people will realize that. I think mine was on with 3 bolts maybe? I never put it back on b/c it had partially rotted out around one or two of the bolt holes.
Old Jul 6, 2004 | 12:17 PM
Mad Chemist's Avatar
Another suggestion for the writeup is the use of a bit of teflon tape on the threads of the fitting to get a nice seal, but avoiding blocking/plugging the line.
Old Jul 6, 2004 | 12:26 PM
Bob_98SR5's Avatar
David,
Ok another good suggestion, but I didn't use teflon tape. Maybe I will since I have to re-do this anyways.
Bob
Old Jul 6, 2004 | 02:47 PM
AznSky's Avatar
another suggestion since bob is ignoring my IM's:
Tighten it as hard as you can!! Reason I was sprayin everywhere was because I thought by holding onto the filter and tightening it with a 14mm wrench was enough, until I finally listened to my dad and held the filter nut with an adjustable wrench and tightened the ˟˟˟˟˟ outta both fittings with the 14mm wrench.
Old Jul 6, 2004 | 03:54 PM
Bob_98SR5's Avatar
double nimrod!
dude, i wasn't ignoring you. i was at the gym. nerrrrd!
and rob, im not advising anyone to tighten the S out of anything! are you sure you aligned everything properly before tightening down? i didn't have to excessively tighten down anything. ill see if i can dig up the torque specs but it wasnt bad at all.
bob
Old Jul 6, 2004 | 04:55 PM
AznSky's Avatar
yea i'm pretty sure everything's aligned. It's just that when I used the double wrench method, i got a few more threads in and that tightened up everything. I guess I'm just a weakling.......
Old Jul 15, 2004 | 01:24 PM
Bob_98SR5's Avatar
Guys,
I got the part in a few days ago and i can say w/o a doubt that the acceleratoin is a bit peppier.
Bob
Old Jul 18, 2004 | 06:25 AM
ElwayLite's Avatar
Nice writeup, I did mine a few weeks ago and what bothered me was when i pulled the filter down and set it on the ground, black fuel drained out of it, looked like someone had mixed fuel and coal. I think anyone that thinks this is not a 30k mile item is nutso
Old Nov 9, 2004 | 07:44 AM
ugadawg95's Avatar
Replaced mine last night. That is cake! Definately use goggles/glasses and latex gloves. That undercoating is a bi*ch to get off! Thanks for the writeup Bob!
Old Aug 4, 2005 | 01:17 PM
WraunVT's Avatar
How often do you think this should be done?
ladybugRC
458
Aug 21, 2020 10:41 AM
nvwiggins
13
Jun 16, 2016 03:05 PM
Jdgarrison
Oct 1, 2015 05:22 PM
Rcbc92
Sep 26, 2015 03:00 PM
themightykhoner
Sep 18, 2015 02:28 AM
