2nd gen 4runner front end question
Old Mar 18, 2005 | 11:08 AM
BeevDawg's Avatar
ok, someone told me that the toyota truck front end parts(fenders, grill, lights, etc...) from 89-95 are interchangeable with the 2nd gen runners. Now if this is true, I should be able to just slap some corner lights from an 89-95 truck and be able to fit fenders from trucks of those years correct. The reason I ask is because there is a really sweet fiberglass fender kit I like that says works for the 89-95 truck, and if what I was told really works, I should just be able to do that to get those fenders on. Sorry this is sort of confusing, but can anybody clear this up for me what is fact, thanx.
Old Mar 18, 2005 | 11:56 AM
eric-the-red's Avatar
I'm not 100% sure, and I've never tried to change parts, but the front of my 93 4Runner looks a lot like the front of my friends 93 truck. I'm guessing fenders, etc would be interchangeable.
Old Mar 18, 2005 | 12:48 PM
Flamedx4's Avatar
Far as I know they interchange. Just give it the ol' eyeball double check first...
Old Mar 18, 2005 | 12:53 PM
sherri_girl's Avatar
they should be the same as long as the application is for a 4wd.
Old Mar 18, 2005 | 02:01 PM
ed's Avatar
ed
The grill & lights are not interchangeable for all those yrs. In either 92 or 93 the 4runner went to curved, composite headlights (instead of the rectangular H4s) which also affected the grill. (This isn't obvious unless you're looking for it.) I don't know if this affects the fenders, try asking a salvage yard or a toyota parts counter?
I wish they were interchangeable cuz it'd be nice to change out the headlights to some eurospecs cibie's, but everything I've heard says no go.
Old Mar 18, 2005 | 02:05 PM
it changed in 92
Old Mar 18, 2005 | 02:07 PM
green91runner's Avatar
fenders & corner lights are identical, the grill/headlights are different but still interchangable with a couple holes drilled. the mounting points are slightly off, to allow for the curved headlights. got the closer look at it when i was contemplating replacing my cracked 91 grill with a pristine 92 grill... ended up deciding not to do it, because i just like the look of the 90-91 over the 92-95
i mean, 3rd gens are paying extra for the 'TOYOTA' (satoshi), then it's gotta have something going for it
Old Mar 18, 2005 | 02:19 PM
BeevDawg's Avatar
you guys tell me, if I got the same cornerlights as the 89-95 could I get this kit to fit?
Old Mar 18, 2005 | 02:21 PM
That is a 2wd front, your corner lights face the other way, so you'd have to get 2wd corners
Old Mar 18, 2005 | 02:31 PM
BeevDawg's Avatar
yup, thats what I mean, do you think I would run into any other problems after I put 2wd corners on?
Old Mar 18, 2005 | 02:35 PM
did you call the company that makes those fenders and ask? - cause I cant think of anything that would give you problems otherwise...
what year is your Runner?
Old Mar 18, 2005 | 02:38 PM
ed's Avatar
ed
[QUOTE=green91runner]the grill/headlights are different but still interchangable with a couple holes drilled. the mounting points are slightly off, to allow for the curved headlights. got the closer look at it when i was contemplating replacing my cracked 91 grill with a pristine 92 grill... [QUOTE]
hmmmm, are there common mounting points between the two that could be used as a ref, particularily for the headlight buckets? (putting the early/truck style lights into a 94 4runner, the grill I'm not so concerned about except that for used parts you may have to get the whole setup)
hmmmmmm
Old Mar 18, 2005 | 02:46 PM
Babypig's Avatar
The lights mounting screws are different for sure. Tried to do it when i had the 95 that i was parting. The whole rad support is different. It could be done i just didn't feel like drilling a bunch of new holes.
Old Mar 18, 2005 | 04:21 PM
yea, the light mounting would be the biggest step, the grill however would be only a couple holes, a number of them do line up... only thing is, switching from a 92-95 era headlight to a 90-91.. you would have considerable gaps in your front if you didnt switch the grill too.. don't think it would look too good?
Old Mar 18, 2005 | 11:01 PM
Babypig's Avatar
Hey,
know any Hartviksons there in T bay. They are probably my relatives if you do. Love it there. Any good wheeling around that area?
Old Mar 19, 2005 | 12:04 AM
Originally Posted by Babypig
Hey,
nope, can't say i do.. godzilla (on yt) is also in tbay, he might know them.. as for wheeling spots.. i really haven't had my runner that long, and i've been too busy/buck strapped to really have the time to search them out. but im sure theres lots of places.
Old Dec 12, 2007 | 04:51 PM
4runnerinsd90's Avatar
95 4Runner Fiberglass Fenders?
Im Looking For Fenders, but I want some that are quality fenders
Jdgarrison
Oct 1, 2015 05:22 PM
marcusSRG
Jun 27, 2015 07:13 AM
YotaGreenhorn
Jun 27, 2015 07:00 AM
Niameyrider
Jun 25, 2015 05:50 AM
infinityisfive
Jun 16, 2015 06:51 PM
