285's...LETS CLEAR THIS UP PLEASE!
Pro Com 285/75-16's on OEM Alloys
1. OEM springs and Daystar spacer lift.
2. No trimming done, however they do rub on factory mud guards when flexing and on the frame when i turn the wheel full crank to one side or the other.
3.
4. I didn't spend much money.... It gets the job done.
3.
Hope this helps
Luke.......... now got a 3rd Gen
You guys might me interested in a thread i made on Yotasurf UK here it is...............
http://www.hiluxsurf.co.uk/forums/sh...ad.php?t=36921
OME lift in the UK just another take on it
Luke
#25
1) OME 883s on N91 shocks up front
Cruiser coils with ProComp ES1000s in rear
*2" body lift*
2) No body rub whatsoever, tiny rub on a-arm, solving with 1/4" wheel spacers
3)
4) I absolutely love it
and about the wheels, yes 285s/305s and even 315s will fit on stock wheels, most change for look/backspacing. i think toyota nailed it right on the head with the 5 spokes so i got those
*2" body lift*
3)
#28
1) what lift kit you used, (shocks, spacers, coils, etc) in front and rear
Sonoran Steel #1.1
2) did you have to do any trimming to prevent tire rub?
Yes, minor up front. Pinch weld trimmed back and well liner trimmed. Still some rubbing on frame at full turn. No plans for a body lift.
4) Are you happy with your combination?
Works good, last long time.
3) A picture of your ride if you have one
Click here ---> http://img.photobucket.com/albums/v416/111db/4Runner/97.jpg
Sonoran Steel #1.1
#32
There are many factors that go in to rubbing. The main thing you have to ask yourself is how much wight your going to add to the front end of your vehicle...? Are you going to want to add an aftermarket bumper, winch, skidplates, if you have limited flares or if you want to add bushwacker fender flares etc. You have to match the lift to the amount of weight you plan on adding to the truck.
#34
Matt, your 99 is amazing. How do you like the maxxis tires? What is the treadlife like? How much lift does the fabtech suspension give you?
#35
1. OME 3inch with top out spacer(toytec),LC rears OME shocks, 2in RBBL. 285/75/16's on stockies.
2. Minor rub at full crank, shaved upper a-arms, and minor fender/mud guard trim.
3.[IMG]
[/IMG]
4. Absolutely LOVE IT!
3.[IMG]
[/IMG]4. Absolutely LOVE IT!
#36
1. LC rear coils and 2.5" Daystar front spacers with Rancho RSX shocks. 285's with stock wheels.
2. Minor rubbing at full steering lock. Trimmed running boards and front valance.
4. The setup works well, but would like another 5. - 1" in the front to match the rear.
#37
i installed revtek 3in. suspension lift with 285's on my 99 3rdgen and had rubbing issues. put roger brown 1 inch body lift and black steelies 16 x 8 3.75 backspacing and its been smooth sailing ever since. on and offroad.
#38
Thanks for the compliment! I really like the Maxxis tires. They perform really well off-road and are really manageable through town and on the highway. I guess I've probably put 5k miles on them so far and haven't noticed any visual wear yet. My only complaint is that they spin quite a bit in the snow when in 2wd, but that is to be expected with mud specific tires and it is nothing 4wd can't take care of. The Fabtech coilovers are probably giving right around 2.5" of lift right now. I'd like to raise them up a bit to compensate for the LC rake but I'll wait until I send them in to be rebuilt to do that.
#39
This is what my brother is running, and what I plan on running, except with MTRs.
1)OME 882/890 Rock Krawler 16x7 4"BS 285/75r16 BFG MTs
2)After alignment it only rubbed on the front bumper at full lock. had to trim millimeters off to keep it from rubbing. not a problem now that the ARB bumper is on there
3)
4) get the 10mm rear spacers. the truck still looks saggy otherwise
3)
live4soccer7
May 11, 2016 06:52 PM
JookUpVandetti
Sep 30, 2015 08:58 AM
charlie_fong
Sep 27, 2015 10:06 PM
