265/70/16 or 265/75/16???
Old Mar 19, 2003 | 06:15 PM
tigers's Avatar
I am about to get a set of tires for my 01. But which size should I go with and what is the difference? Is the 75 taller, wider, or both? Also will going to a 75 void the warranty? Mostly likely going with the KOs. Thanks for the advice.
WCR
Old Mar 19, 2003 | 06:17 PM
Scottiac's Avatar
265 is the width in milimeters, so that's the same. It's basically the difference between a 31" and a 32" tire.
I can't imagine it would affect your warrantee at all.
Old Mar 19, 2003 | 07:38 PM
MY024runner's Avatar
The 75 are taller
Old Mar 19, 2003 | 08:59 PM
dave89144's Avatar
check out the 275/70 while your at it, they are right in the middle... 1/2 inch taller than 265/70, and 1/2 inch wider tread
Old Mar 19, 2003 | 09:07 PM
ALee27's Avatar
that size is pretty rare and will prob be hard to find. mine as well go with 285s!
Old Mar 21, 2003 | 04:02 PM
4RunnerFever's Avatar
calculating the tire size
Here is an easy way to calculate the tire size in inches.
take the width and divide by 25.4. Then multiply by the aspect ratio (e.g. .7 or .75). this is the sidewall height.
next multiply the side wall height by 2. this is the total height of the tire.
finally add the size of the rim (e.g. 16 inch) and voila! the total height of the tire and the rim.
Old Mar 24, 2003 | 05:25 PM
tigers's Avatar
Thanks,
Has anyone had problems with the 75s rubbing? Here I can get the 75s for about a $100 cheaper, but my wife will be driving the 4R alot and I don't want the tires rubbing. We have a limited with the running boards and all the side trim.
Old Mar 24, 2003 | 05:58 PM
ChitRod's Avatar
Originally posted by tigers
Thanks,
I just got a set of 265/75 m/t and no rubbing.
Old Mar 24, 2003 | 06:09 PM
cybrenergy's Avatar
Will the 265/75's fit on a stock truck? Is that the largest size a stock truck with 16" can fit?
Old Mar 24, 2003 | 07:41 PM
Scottiac's Avatar
Yep, the 265/75r16's fit just fine on a stock '97 LTD with all the trimmings. (Not running MT's, but everyone seems to think they're fine.)
I'm pretty sure bumping up to the 285/75's will give you problems in a stock rig, so yeah, that's pretty much the line.
aowRS
Sep 13, 2017 08:22 AM
makemusic116
Aug 2, 2015 05:23 PM
makemusic116
Aug 2, 2015 04:40 AM
ugabulldog
12
Mar 1, 2005 03:03 AM
mdavidh
9
Oct 28, 2004 10:29 PM
