22re woes
Old Sep 23, 2004 | 02:35 PM
desert whomper's Avatar
22re woes
ok my 22re around 800-1000 rpm will rev dies then rev and die..... no clue why. also i changed my spark plugs, all looked good except number 4, it was really messed up had a bunch of bumps on it like carbon build up and when i pulled it out it had gas on it. none of the others were like this. good there be a connection here?
Old Sep 23, 2004 | 04:40 PM
seaflea's Avatar
Could be youre TPS. I had one go bad, all it would do was idle. Anything above that and it would stall. Took me almost an hour to get home!
The bumps on the #4 sound like predetonation, but not really sure.
Old Sep 23, 2004 | 06:18 PM
sick4runner's Avatar
could also be the ac doing something wierd, check to see if it still happens with the ac off? and maybe check some of the vacuum lines to the throttlebody etc, just start pokin around under the hood
Old Sep 23, 2004 | 08:47 PM
all my vacum lines are in really good condition, all go to where tier supposed to and i dont have ac or power steering so niether of those will affect it, could it be a bad vavle or seat cuz the spark plug was wet with oil and gas. i think mostly gas tho. cant i adjust the throttle position sensor, i looked and u can adjust it a little bit, is there a way to find the right setting?
Old Sep 24, 2004 | 02:01 PM
ok, u took it to a friends shop and he said itsnt the TPS maube the PCV could be bad but i replaced it and still have the problem i do know now that a valve needes to be adjusted, maybe all of em but something is up somewhere in the emmsions part of my engine, any ideas?
Old Sep 26, 2004 | 09:20 AM
i figured it out it was my tps sensor, i adjusted it and it was bad so i got a new one, my guess is it was telling the engine to run too rich and would cause it to sputter
Old Sep 26, 2004 | 10:02 AM
4Crawler's Avatar
The TPS doesn't tell the engine to run rich or lean. It just tells the ECU how far open the throttle is and most importantly, when it is closed so that the ECU enters the stable idle mode (vs. the "running at low RPM mode"). If the idle contact in the TPS is not closing at the right place, you won't get a smooth idle:
http://www.4crawler.com/4x4/CheapTricks/TPS/index.shtml
JNapolitano
Nov 14, 2019 07:46 PM
Stull
Aug 28, 2015 05:53 AM
ia02
Aug 20, 2015 11:04 AM
PlayAwhile
Jul 20, 2015 11:36 AM
