22re timing issue
Old Dec 4, 2004 | 11:33 AM
ekim121's Avatar
22re timing issue
Just wondering if you guys had any insight before I take it to the dealer...I was setting the timing on my 93 22re and noticed that when I put it where it was supposed to be (5 degrees before tdc) the engine had no power. I could get the engine to make normal power, but it required me to manually advance the timing to probably 30 degrees. It runs great at that setting...no pinging, makes good power...runs like it did before. The problem is that it gets awful gas mileage out there...around 15mpg on the highway. I'm thinking it's the ecu...and I'm having to manually advance the timing to compensate for something wrong in there...any advice?
Old Dec 4, 2004 | 11:59 AM
Joyota's Avatar
While you set the timing, did you put a jumper between Te1 and E1 in the little gray box by the fuses under the hood? If you didn't, try that first. Also, when you hook that jumper up, your idle should change a little, I think about 50-100rpm. If the idle doesn't change, your tps probably needs to be adjusted. As far as mpg, I'm getting about 14mpg city/highway combined, but still think that's a little low, due to a bad AS Reed Valve.
Old Dec 4, 2004 | 01:41 PM
ekim121's Avatar
My thought is that something is wrong because when I put in the jumper wire it is making the connection, as the check engine will blink, however, it does not affect the idle speed...that's why I was guessing ecu...
Old Dec 4, 2004 | 02:40 PM
SoCal4Running's Avatar
I vote for the TPS.
Old Dec 4, 2004 | 05:55 PM
yotafreakshow's Avatar
How many miles on the timing chain? I had one slip a tooth, and it made no power until I advanced the timing about 25 degrees. Ran it for a couple of months that way before putting a new chain in...I'm sure there was a ton of detonation going on there though. Hopefully it's your TPS.
Old Dec 4, 2004 | 08:42 PM
Joyota's Avatar
I would try the TPS, before doing anything else. Check out Roger Brown's Site. He saved me a bunch of work! Good Luck!
Old Dec 5, 2004 | 08:09 AM
Nathan Buchanan's Avatar
I'll bet your timing chain has jumped a tooth. The same thing happened to me. The really bad thing about advancing it a lot and running it like that is that you don't know when the chain will jump another tooth and kill your valves.
Old Dec 5, 2004 | 06:25 PM
PirateFins's Avatar
I'd say timming chain also & TPS. While you are into it make sure you get some metal backed t-chain guides instead of the plastic ones.
Old Dec 5, 2004 | 08:09 PM
tim1's Avatar
just went through this
hey bud, I just went through this whole senereio. Turns out that the tps was not fully closed at idle not allowing to set the timing properly. Adjust this and you'll see the change in the timing when you pull the jumper off the te1. Tim
Regency
20
Jan 3, 2020 07:43 PM
CJ94yota
Jul 3, 2015 10:14 PM
saphirekosmos
Jun 22, 2015 10:26 AM
bobbybouche
Jun 18, 2015 10:22 AM
