22re question
Old Dec 20, 2004 | 01:24 PM
bsmi16490's Avatar
22re question
I just had the head redone on my project 4runner and reassembled it, I sent to a mechanic to have him check over all my work and make sure everything was straight, he did and said everything was good, set the valves and all that good stuff, well i get it back and it hesitates to 2000 rpm and once over that runs fine, it even idles good, but if you are in gear with a load on the engine, it hesitates, the reason the motor was diassambled was two burnt valves, what is going on, I have no idea and I am not going to tak it back to the mechanic and definitely cant afford to go to toyota dealership??????????help please???
Old Dec 20, 2004 | 02:49 PM
bsmi16490's Avatar
bump, come on guys help me figure this out
Old Dec 20, 2004 | 03:03 PM
bsmi16490's Avatar
Bump Again
Old Dec 20, 2004 | 05:39 PM
desert whomper's Avatar
check out the tps
Old Dec 20, 2004 | 05:40 PM
bsmi16490's Avatar
i was told by the mechanic that worked on it that it could be the cold start solenoid
Old Dec 21, 2004 | 11:07 AM
Yamaha+Toyota=Fun's Avatar
How about cleaning the T.B. You probally have already done that though. I also think the tps could be it.
Old Dec 21, 2004 | 05:15 PM
bsmi16490's Avatar
it was the timing, two teeth off on the cam gear, timing light was showing it was at 8 degrees but the cam gear was not reinstalled in the right spot
Old Dec 21, 2004 | 07:29 PM
colsoncj's Avatar
thanks for posting the solution!
Old Dec 21, 2004 | 07:58 PM
yotafreakshow's Avatar
I was going to suggest timing alignment, then I scrolled to the bottom of the page...nice work!
coleypull15
Nov 3, 2015 07:41 AM
tj884Rdlx
Aug 28, 2015 12:04 PM
thefishguy77
Jul 30, 2015 10:59 AM
rushw
Jul 18, 2015 01:46 PM
icentropy
Jul 14, 2015 10:23 AM
