2001 3.4 cylinder 6 misfire. PLEASE HELP
Old Oct 24, 2018 | 06:54 PM
2001tacoma_trent's Avatar
I bought an 01 tacoma about a month ago. Every has been fine, no issues at all. Well earlier this week when driving my kid to school I get a really bad shaking when I accelerate >2000 rpm. I took it to look at the CEL. P0306.
So I swapped out spark plugs with NGKs. Still same issue.
I checked my spark plug wires with a fluke, and they checked out fine, but I haven't replaced them. I swapped around coil packs, but it's still with #6. I replaced fuel filter and replaced the fuel injector for #6 and i still have the misfire.
Any help would be greatly appreciated!!!
Old Oct 24, 2018 | 07:08 PM
millball's Avatar
Compression test
Old Oct 25, 2018 | 10:30 AM
So I just finished up with compression test. All cylinders were around 210, except #3 which was around 180.
also, I've been driving around quite a bit today, but my CEL hasn't come back on, or blinked at me at all.
Old Oct 27, 2018 | 10:40 AM
ZUK's Avatar
ZUK
See if the #6 wire has any arcing with a night time check.
Old Oct 27, 2018 | 10:45 AM
worth a shot. Thanks
Old Oct 28, 2018 | 09:17 AM
fierohink's Avatar
You have a dying injector. There was a spate of failures a summer or so ago. Besides a set of eBay injectors you’ll need an intake plenum gasket set for about $20.
Old Oct 28, 2018 | 09:18 AM
fierohink's Avatar
Was the CEL blinking when it was missing?
Old Oct 28, 2018 | 09:50 AM
Fixed
So I found the problem. It was a spark plug wire. I checked them with a fluke, and they checked out fine so I completely over looked them. Should've stuck with the basics and just changed them. Stupid me lol. But thanks to everyone trying to help.
Old Apr 26, 2021 | 10:46 AM
sharrack's Avatar
Not sure what it is but 3rd gen v6's eat spark related items on a regular basis. I've had 2 plugs go south at different times and one only lasted a year. Maybe its the intense heat inside the valve cover tube. .....
wires as well......never discount the things you've rarely ever had go bad. 3rd gen v6's are different
jjuliefaye
Apr 26, 2021 07:15 AM
LH0525
Dec 29, 2019 04:17 PM
amocat95
23
Apr 27, 2010 04:45 AM
VML4runner
42
Mar 2, 2010 09:05 AM
Jcod12
Feb 21, 2008 02:29 PM
