2000 front wheel bearing replacement. How hard?
I have a growling sound going around corners, it seems to be coming from the left front. The brakes and everything look ok, so I am wondering if it's a bad wheel bearing.
If so, how hard are they to replace?
Originally Posted by vegaskurt
I am pretty sure the bearing has to be pressed out and a new one pressed in but I could be wrong.
Does this sound like a bearing? It seems to get louder as the car gets hotter.
It sounds like it's from the left front, but gets worse going left. Usually a bearing will do it on the left when making a right turn.
You'll be surpised, I had a 98 grand prix GTP that had a bad bearing. I thought it was the driver side,I decided to replace both sides since I thought the passenger side will go out soon after. I started w/ the passenger side first.Before I jumped to do the driver side(the bad one,err so I thought) I took it out for a spin.Problem solved,took back the other bearing for a refund, since then no probs. You mentioned it gets worse as it gets hotter, I take it that you mean faster, because mine sounded like an airplane ready for take off the faster I went. If you take it to the shop get OEM bearings.
Avenged
Jul 9, 2015 07:55 AM
skoti89
Jul 8, 2015 12:05 AM
cyclist231
Jul 7, 2015 12:56 PM
