O2 sensor
Old Jul 18, 2006 | 06:22 AM
jev2022's Avatar
O2 sensor
Is changing the oxygen sensor on the 3rd gen trucks a 1-2-3 job or is it a challenging task?
Old Jul 18, 2006 | 06:39 AM
GSGALLANT's Avatar
It's extremely easy as long as you can get the nuts off. I removed mine and ended up stripping the nuts slightly, so I just replaced them. Spray them down with a rust penetrant once a day for a few days before you need to remove them and you may have no problems at all.
Old Jul 18, 2006 | 06:52 AM
OutdoorLiving's Avatar
I didn't have ANY problems with the bolts at all. It took me a half-hour hugging the top of transmission trying to disconnect the sensor from the wiring harness. Perhaps it's located somewhere else for Autos. The connector couldn't be in a worse place on the manuals, though. Still not worthy of a stealership repair, but I thought it was a pain in the ass and worth mentioning.
Old Jul 18, 2006 | 06:58 AM
GSGALLANT's Avatar
It's easy to get to on the Automatics.
Old Jul 18, 2006 | 09:19 AM
I just replaced my O2 sensor last saturday. took me about 30mins and I took my time slowly and Im not even handy when it comes to machanical. One advice is let the engine cool down.
Old Jul 18, 2006 | 09:35 AM
Bob_98SR5's Avatar
jev,
you really need to search more often, bud! this is a pretty well covered topic as of late.
also, i have a writeup in the tech forum that will show you how to do this.
bob
Old Jul 18, 2006 | 10:36 AM
jev2022's Avatar
O2 sensor
Ok, thanks Bob. But where is it? If I had seen a write up on it, I probably wouldn't have posted the question.
Old Jul 18, 2006 | 10:55 AM
Courtesy of the Tech Write-Ups Section
Old Jul 18, 2006 | 11:05 AM
jev2022's Avatar
O2
Got it. Thanks!
Old Jul 18, 2006 | 11:39 AM
kmcc78240's Avatar
quick high jack please excuse me
is there a write up on the second gens or is it all about the same? or could you point me in the right direction
Old Jul 18, 2006 | 11:44 AM
Elton's Avatar
^ pretty much the same
Old Jul 18, 2006 | 01:02 PM
MaNiAk's Avatar
I just changed mine yesterday. My first time, took 15 mins. Tools you need are 13mm, a flexable socket wrench, a screwdriver (flat head) to push in the little tabs to remove from the harness. once the sensor hangs down you use the screwdriver once again to release the tab on the side of the wiring harness plug ( please excuse the lack of correct terminology) Then go backwards. I live in az so rust in not a problem here. removal of the nuts went very well. Oh don't forget the anti-seize lube. Then you pull the 20a EFI fuse for a bout a min. I noticed a more smoother ride throughout the rpm bands, Before it got a little sluggish in certain rpm bands, runs like a champ again. Oh I hade 85000 miles on it and had no CEL, just thought it was time to replace it.
Old Jul 19, 2006 | 02:53 AM
I didn't have any anti-seize lube. I hope the healthy application of WD-40 does the trick in a year or so...
Old Jul 19, 2006 | 03:30 AM
GSGALLANT's Avatar
WD-40 will not help when you have to take this off again. Ohly a high heat anti-seize stands a chance on the exhaust system.
However, for you, since you are in northern Georgia (I think), you shouldn't have any rust problems anyways, so you should be fine.
Old Jul 19, 2006 | 04:51 AM
MTL_4runner's Avatar
Some antisieze formulas can also damage sensors so be careful not to get any on the sensor tip or inside the exhaust.
Old Jul 19, 2006 | 05:19 AM
Quite honestly, I'm not too worried about it. If I ever remember to pick up any while I'm in the store, I'll unthread it and reapply. But it came off so easy, I could have sworn it wasn't torqued down properly to begin with!
Old Jul 19, 2006 | 05:45 AM
You live way outside the rust belt so I wouldn't worry too much about it anyway.
moparbay
Mar 10, 2023 03:50 PM
jb451
7
Oct 7, 2022 06:58 AM
Kreedy1
Sep 8, 2015 06:33 PM
zz_denis
Sep 6, 2015 03:43 PM
moparbay
Sep 3, 2015 12:48 PM
