2000 4runner auto to manual
Old Apr 6, 2014 | 03:48 PM
22REFORME's Avatar
I just bought two 2000 4runners, one is wrecked in the front end but has a good 3.4 and 5spd transmission the other is a 2000 sr5 auto with rear locker. according to the previous owner of the auto, the transmission is bad though it does drive. i need to investigate weather the auto is actually bad or if its something silly like a cv or universal.
If the auto ends up being bad i want to swap in the stick from the other truck. I have done some searching but was curious if there were any good threads out there from people that have already done this?
Things i would like to know:
is this a bolt on affair? if not what has to be moddified/welded/cut/bent?
can i get away with just swapping the engine harness and ecm or do i have to do the truck main harness as well? any tricks to run the auto harness with manual ecm?
anything i am missing?
side note, what kind of oem spec clutch kits do people like for these 4runners?
thanks very much for the help.
Old Apr 6, 2014 | 06:47 PM
22REFORME's Avatar
just found this thread...
https://www.yotatech.com/forums/f2/1...tmares-250972/
exactly the same symptoms... we shall see.
Old Apr 6, 2014 | 11:37 PM
wyoming9's Avatar
Red face
As you have all the parts in a complete vehicle .
The putting the holes in for the clutch Master Cylinder opening the hole in the floor for the shifters about the only work.
you will have some work in the harness area .
The Auto ECM can be repined to work with the manual transmission who knows since you have both ECM`s and harnesses which would be easier.
you have the drive shafts to change around.
Clutch quite a few to choose from I run a LUK on one a Aisin on the other people do say Good things about Marlin Crawlers clutch
Old Apr 7, 2014 | 05:30 AM
22REFORME's Avatar
are there write ups on these modifications?
driveshafts are different lengths i am assuming due to the auto trans being longer?
one thing that i just thought of, are there different gears in any of these trucks?
Old Apr 7, 2014 | 07:32 AM
Jomoka's Avatar
I think in very general terms, most non-locked 3rd gen 4Runners will have 4.10 gears, and most locker equipped will have 4.30. Which means you'd need to swap the front diff as well. In vague theory the door frame sticker lets you know what diff type and ratio you have, but in reality I think you just need to check it manually.
Old Apr 7, 2014 | 08:32 PM
22REFORME's Avatar
thanks i'll check that out
Old Apr 8, 2014 | 06:15 PM
22REFORME's Avatar
i can't seem to find a refference for checking the door sticker, but from reading it would seem that i have 4.30 due to having the rear locker. the auto's transfer case is not usable with the 5spd trans? i REALLY dont want to swap fron diffs...
heres my door tag:
progress report, transmission is ready to drop.
Old Apr 9, 2014 | 05:35 AM
Jomoka's Avatar
The door stickers seem to be a bit hazy, I really think you're best served just spending some time doing an actual test on the diff.
We're in the middle of a locker swap onto my wife's '96 manual 4Runner, using a locker axle from an automatic. Her original ratio was 4.10, the automatic locker axle was 4.30. We found the rear axle first on CL, then had to look around for a matching 4.30 front diff. And yes, the front diff is a PITA. It sort of mildly looks as though it might be fairly easy, but it's tucked rather snugly between the engine and crossmember, and the steering rack and sway bar gets in the way as well.
I have a '99 manual locker (Highlander) - I'm not entirely sure what ratio I have, I've never checked.
Old Apr 9, 2014 | 07:47 AM
22REFORME's Avatar
i am confused... i have the rear locker and the matching front diff already, if i am just swapping the transmission and tcase why do i need to swap the front diff?
Old Apr 9, 2014 | 09:29 AM
Jomoka's Avatar
Sorry, reading comprehension failure on my part. I lost track of which parts were going where. I thought you were swapping a locker rear axle from the wrecked one to the good one.
Old Apr 9, 2014 | 11:45 AM
22REFORME's Avatar
whew
which transfer case should i use or can i only use one?
just ordered an exedy 16087 clutch kit
Old Apr 11, 2014 | 04:04 AM
22REFORME's Avatar
stripped the donor truck yesterday. if anyone needs parts speak now ...
ordered a new flywheel that way i can resurface this one and have a spare.
Old Apr 11, 2014 | 08:00 AM
TheDurk's Avatar
How's the interior? I just need some oak trim.
Old Apr 11, 2014 | 09:16 AM
Jomoka's Avatar
I have seen the occasional thread here and there were people pondered putting the AWD transfer case onto a manual trans, but I don't recall seeing where anyone actually did it.
AWD would be a nice option for the occasional trip on pavement where it is half-snow covered.
Old Apr 11, 2014 | 09:18 AM
22REFORME's Avatar
Its not great... also no oak. Check the parting out section of the classifieds
Jun 1, 2021 01:51 PM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
mskalmus
May 28, 2017 07:51 AM
Avenged
Jul 9, 2015 07:55 AM
Jnkml
Jul 6, 2015 01:20 PM
