2 Things to Ask about
Old Nov 5, 2003 | 09:35 PM
Brad's Avatar
Hey Ya'll-
Two things-
My heater isn't very hot. It gets warm at best. Any thoughts? 2nd thing is I need a good online junkyard or parts store. I shut the door a little too hard the other night and broke the clip that keeps the back window shut. Any ideas??
Thanks
The snow has been coming down in Utah!!!
Old Nov 5, 2003 | 10:37 PM
joshik's Avatar
www.yotayard.com for the online junk yard.
the heater, maybe someelse can help
Old Nov 6, 2003 | 12:53 AM
TACOMANATOR's Avatar
Replace the thermostat.
Old Nov 6, 2003 | 07:42 AM
BT17R's Avatar
Yep, although it could be a buggered (technical term there) heater control cable that adjusts the heater core coolant flow valve, the valve itself, or (hope not) a partially clogged heater core.
Old Nov 6, 2003 | 03:00 PM
dbullock15's Avatar
Start with a new thermostat and do a coolant flush while you have it apart. If that doesn't fix it then you can at least narrow it down.
When was the last time the coolant was changed?
Old Nov 6, 2003 | 03:08 PM
Cebby's Avatar
My Celica had that prob once. Replaced the T-Stat and it was cured. Tacomanator got it on the money...
Old Nov 6, 2003 | 03:14 PM
Krash's Avatar
Make sure you price around local before going to them, they are a bit pricey.
As for the heatercore, I would try everything someone mentions before changing the heater core. Its not that difficult just a PITA. I would bet its either clogged or something on the way there is clogged, because if it was leaking you would have mentioned something about your floorboards being wet all the time.
Eggslinger
Jun 8, 2019 03:32 PM
dumpster84
Apr 30, 2016 06:03 AM
Dennisx2
Aug 10, 2015 06:48 AM
JHalcyonM
Aug 4, 2015 01:19 PM
HookahRoo
Jul 20, 2015 07:06 PM
