2.1" supercharger pulley installed
Old Jan 16, 2007 | 07:10 PM
kevin444's Avatar
I have supercharger on ebay! look under ebay seller "lilshyboy" = )
hey how much was the spoiler and who makes it.
Old Jan 16, 2007 | 07:22 PM
99LimitedKS's Avatar
I'm broke. Just did a $700 stereo.
And JAOS makes the spoiler.
Old Mar 28, 2007 | 10:47 AM
SEAN_at_TLT's Avatar
I have a related question.
I'm running the URD fuel upgrade kit with IPT VB upgrade and a trans cooler. What size pulley can I safely/effectively run with this setup? I'm not a drag racer but I like dropping the hammer now and then....
Old Mar 28, 2007 | 10:54 AM
mastacox's Avatar
2.2" pulley is a safe bet if you don''t have an EGT gauge, maybe a 2.1 with an EGT gauge. Any higher will require water/methanol injection.
Old Mar 28, 2007 | 11:01 AM
  #25
sweet, thanks. What kind of flywheel HP can I expect with that?
Old Mar 28, 2007 | 11:04 AM
  #26
mastacox's Avatar
Most people estimate about 320 at sea level with a proper tune.
Old Mar 28, 2007 | 11:19 AM
  #27
very nice.....very nice indeed! I'm sure I'll be chiming back in once I get to the tuning aspect.
Old Mar 28, 2007 | 11:24 AM
  #28
mt_goat's Avatar
Is that with the 2.2 pulley?
When I was talking to Brian @ URD he said 2.2 was the smallest you want to go without WI, with WI 2.1 was ok, and 2.0 would spin the SC past the rated max rpm.
Old Mar 28, 2007 | 11:39 AM
  #29
yeah, with the 2.2".
Old Mar 28, 2007 | 12:01 PM
  #30
mastacox's Avatar
Yup, 320 crank hp with the 2.2" pulley.
I mentioned the possibility of running a 2.1" pulley as long as you have an EGT gauge, but you would need to keep a close eye on that gauge and back off on the throttle if you get close to catastrophe. It's obviously a better option to get WMI with the 2.1" pulley.
As for the 2.0" pulley, I wouldn't be interested in trying it. It pushes something like 15psi of boost I think and when boost gets that high I would be on the border of wanting to get an intercooler, meaning either turbo or centrifugal supercharger would have to replace the roots one.
Old Mar 28, 2007 | 01:12 PM
  #31
mt_goat's Avatar
Since you brought it up At what temp would catastrophe happen anyway?
Old Mar 28, 2007 | 02:36 PM
  #32
midiwall's Avatar
Lemme guess! 1550* is where I was running when things burned... I would think that 1600* would be pretty sudden bad news.
Old Mar 28, 2007 | 03:00 PM
  #33
mastacox's Avatar
Based on Gadget's testing, I think 1450* ought to be the high end.
Old Mar 28, 2007 | 03:13 PM
  #34
midiwall's Avatar
I've always thought that 1450* was max power...
ref:
http://www.gadgetonline.com/Gauges.h...monitor:%C2%A0
EGT Gauge
In my dyno testing max power was between 1400-1450 F. Over 1450 the power would drop off indicating a loss of power from to lean of a mixture.
Old Mar 28, 2007 | 03:18 PM
  #35
mt_goat's Avatar
Nothing like first-hand experience to use as a guide.
Old Mar 28, 2007 | 05:53 PM
  #36
QSVeilside's Avatar
Old Mar 28, 2007 | 07:05 PM
  #37
mt_goat's Avatar
Originally Posted by QSVeilside
If I'm not mistaken, even the 2.1" pulley spins faster than TRD's recommended rpms on the sc.
I think you're right, but only near redline IIRC.
TJWilly
Jul 31, 2015 02:05 PM
anniesball
Jul 29, 2015 11:46 AM
yoterr
Jul 24, 2015 04:29 AM
dinks07
Jul 15, 2015 05:34 PM
mengquis
Jul 13, 2015 10:39 AM
