1999+ Radio/AC Bezel installed in a 1998 3rd Gen. 4Runner *PICS* PART 1
Old Apr 25, 2008 | 08:46 AM
blarchitect's Avatar
_____
Old Apr 25, 2008 | 08:55 AM
Man4God's Avatar
Outstanding writeup...Once an over all price point is reached, I may attempt this.
Old Apr 25, 2008 | 08:57 AM
I forgot to request if anybody has any knowledge of the passenger indicator operation, please let me know.
Thanks
Old Apr 25, 2008 | 09:43 AM
4RUN-GT's Avatar
Smile Outstanding!
Excellent and very thorough write up!
Old Apr 25, 2008 | 10:40 AM
Thanks Man4God and 4RUN-GT.
I compiled this with a novice like me in mind!
Old Apr 25, 2008 | 11:49 AM
JC_ez's Avatar
Thanks for the writeup! Just a tip, you are not supposed to remove the white retaining clip to take the crimps out. You just have to lift it up until it stops moving (do not force it).
EDIT: I see that you mentioned the above already and I missed it. Anyways....an extra reminder for anyone else who misses it.
Old Apr 25, 2008 | 12:33 PM
If anybody else has done this swap, feel free to chime in if you have any other additional information. It would be a great help for the next stages.
Old Apr 25, 2008 | 12:47 PM
NorCalVP's Avatar
A+ Great Job... I wish I had done this when I first did the swap. Excellent writeup.
Old Apr 27, 2008 | 06:33 AM
You are right the picture is misleading. I'll rectify this shortly.
EDIT: 29 April '08 Image altered and re-posted
NorCalVP- Thank you for doing this mod in the first place.
Old Jun 1, 2008 | 08:28 PM
Ritzy4Runner's Avatar
Nicely done Blarchitect, as a matter of fact, I picked up another radio bezel and the pigtails this past weekend on my latest boneyard excursion. This one came out of a 99 limited but the wing nut who removed it had no clue and did major damage to the lower portion of the bezel, seems he tried to pry the thing out before removing all the screws then cut (yeah he really did) the 12vdc connectors from all 3 locations using diagonal pliers to cut the lower holders open to pull out the outlests. This is gonna be fun to replace.
My intention with this bezel is to do what you have done so far along with trying to figure out the wiring for all the other connections. If I can figure out what goes where, then I'll rewire what I need to and then use the pigtails as necessary. If it requires soldering will not be a problem for me as I use mil spec soldering at work. Been certified so this will be a piece of cake, trudt me.
As for the connectors, I would rather not cut and splice on this, I have taken several connectors apart for other projects and its not that hard once you figure out what connector is what and how the pins are held in. FSM is very helpful when it comes to that part. If I get this up and going, I will document my conversion as well. If you get it figured out first don't hesitate to post it!
Old Jun 2, 2008 | 12:39 PM
I've figured out the Alarm LED(extended from my existing alarm indicator) and the Passenger seat belt warning LED (wired into drivers one at Combination meter) Can't find the time right now to complete write-up I started two weeks ago!
Old Jun 3, 2008 | 08:29 AM
Part 2 complete.
Link
Team420
Jan 12, 2021 04:57 PM
B. Graves
Jul 3, 2015 04:10 AM
Niameyrider
Jun 25, 2015 05:50 AM
HALMAN
Jun 24, 2002 06:01 AM
westbound
Jun 7, 2002 03:30 PM
