1997 runner rear window stopped working
My rear window on my '97 worked fine from I side switch. I lubes outside key hole which wasn't working because key wouldn't go in keyhole. Got key to go in which now opens and closes window but now the inside switch won't work...
Any ideas?? They literally happened at same time. I put window down with inside switch. Fixed outside switch which then put window down. Got in truck and tried to put window down from inside and no go
Thanks
Thanks
defroster and rear wiper dead as well? That is a clue as to what all is going on.
Get the window back up-whatever way works. That resets the "memory" so to speak.
You're looking at it- you think it is all the way up but its not. The defroster and rear wiper are the clue.
If those are working fine you may have interior hatch panel issues. Just page back in this sub forum or general electrical and you will come across other threads with similar issues.
voiddweller
19
May 2, 2016 09:10 PM
