12v power outlet question
Old Aug 11, 2006 | 12:01 PM
sdstud212001's Avatar
Question 12v power outlet question
We recentlly bought a 2001 Limited 4Runner and I haven't gotten the owners manual yet so I need some help.
Searched no hits
So there are 3 power outlets in the front And I can only get the one with out the covers to work.
There is a power outlet in the cargo area and I can't get that to work either.
Is there a trick to making this happpen?
Old Aug 11, 2006 | 12:05 PM
wjwerdna's Avatar
a fuse may be the trick... i dont know, but maybe they are on different circuits.... what else doesnt work?
Old Aug 11, 2006 | 12:07 PM
I haven't checked the fuse because my wife has it. I think everything else works fine, Well the Antenna does NOT go all the way down flush but I think it's that plastic cable and unrelated.
Old Aug 11, 2006 | 12:15 PM
Bob_98SR5's Avatar
look in the fuse box in the engine bay and check the fuse labeled "15ACC". this is the fuse that handles the cigarette lighters
Old Aug 11, 2006 | 12:18 PM
wjwerdna's Avatar
unrelated... according to the schematics for a 99... the power outlet in back, and the two up front each get power from their own relay...
that could be bad
PWR OUTLET RELAY [ENGINE ROOM R/B] (numbers below are relay contacts for testing)
3-5 : Closed with ignition SW at ACC or ON position
1-GROUND : Approx. 12 volts with ignition SW at ACC or ON position
5-GROUND : Always approx. 12 volts
2-GROUND : Always continuity
there is also supposedly a fuse in engine bay labeled
"(15A) PWR OUTLET"
that goes to the relay, this also could be bad
your ACC circuit activates the relay, but if the ACC fuse was bad radio, antenna, wipers, and a TON of other stuff would not work...
Old Aug 11, 2006 | 12:21 PM
Thanks for the info, now I can get more garage time and less housework time.
Old Aug 11, 2006 | 12:22 PM
wjwerdna's Avatar
pics coming, hold on a sec
Old Aug 11, 2006 | 12:25 PM
wjwerdna's Avatar
this pics will be deleted within a month of posting....
Old Aug 11, 2006 | 12:35 PM
eric-the-red's Avatar
The one without the cover in the front is the cigarette lighter, it's on a seperate circuit from the others. The 2 in the front with covers and the one in the back are on the same circuit. The lighter is on the ACC fuse, and the other 3 are on the PWR OUTLET fuse, chance are that's what's gone.
I have the wiring diagrams for an 01 4Runner, if you want a copy send me an email address.
Old Aug 11, 2006 | 01:03 PM
Bob_98SR5's Avatar
oops, i was wrong but close thanks for the correction, eric and andrew
Old Aug 11, 2006 | 01:04 PM
eric-the-red
PM Sent
Old Aug 11, 2006 | 09:52 PM
Okay so I checked the fuse for "(15A) PWR OUTLET" in the fuse panel INSIDE and it was one of those Large fuses you usually see in the engine compartment. It looked okay to me, still had copper in the window. I didn't see a PWR OUTLET fuse in the engine bay but will check again toinght.
Thanks eric-the-red for the schematics
Old Aug 11, 2006 | 09:58 PM
wjwerdna's Avatar
then using the pics of the schematics or the pdfs, find the relay and test what contacts are do not have the expected results, it should tell you real quick what is working and what is not
Old Aug 11, 2006 | 10:00 PM
Right on
Old Aug 12, 2006 | 01:00 PM
Okay so i got it fixed today. It was a 15 fuse inside the engine bay. It took me a while because I thought it was the one in the dash, then I found the relay in the engine bay and that was not it. Right when I was going to give up I decided to go over them all one more time, and I found it and it was blown. So I changed it out and now they all work well.
Yotatech does it again.
Old Aug 12, 2006 | 01:04 PM
Bob_98SR5's Avatar
SD,
Wait...so i was right? was it the 15Amp ACC? or was it the 15Aamp PWR fuse?
Bob
Old Aug 12, 2006 | 05:23 PM
no,
It was the 15Amp PWR fuse in the engine bay. But there is also an ACC but that goes to the other 12V power, the one without the caps.
Old Aug 12, 2006 | 05:43 PM
wjwerdna's Avatar
glad ya got it there... since those three outlets didnt work, and they are the only thing on the pwr outlet fuse, and all your other stuff worked, pretty much narrowed it down once ya find it
Old Aug 12, 2006 | 06:18 PM
Yep all good now, like I mentioned it is a used 4runner I wonder what made it do that. I will watch it to make sure it stays all good.
Old Aug 12, 2006 | 06:33 PM
Probably someone plugged in too much stuff, with all 3 outlets on the same circuit it's easy to overload, especially with a power inverter.
Btw if you want those outlets to be live all the time check here
https://www.yotatech.com/forums/f127/full-time-power-outlet-mod-99-4runner-75183/
The normal steeing has them live only when the ignition is on.
