10 psi
Old Apr 30, 2007 | 05:53 PM
  #41
my86yota's Avatar
Come to find out, the pully that I took off was a underdog 2.1 pully. It turned out not to be a 2.2 like I was told it was when I bought the thing.
Old Apr 30, 2007 | 06:56 PM
  #42
weiln's Avatar
Theoretically, every 1000' of elevation, you can drop octane by 1 point. Due to the lower level of oxygen at higher elevations, the higher octane is lost, just like 93 octane in a 87 engine, doesn't help at all.
However, I can definitely see a problem if you are trying to force the same amount of oxygen that would normally be had at sea level, into an engine that needs 93 octane. I always though this would cause a problem on FI systems.
When I was in Colorado, I was checking on this because my vehicle at the time was 93 only, and I was concerned about the lack of 93 octane. Since I was 5000' up, I figured I could run 91 with no problems, but I was NA at the time.
I'm glad to see you're doing better though, definitely don't want anything disintegrating.
Old May 1, 2007 | 08:46 AM
  #43
mastacox's Avatar
Yikes, good thing we got you that stock pulley then...
Old May 1, 2007 | 01:47 PM
  #44
my86yota's Avatar
Ya that is what I am thinking. So is there anything else I should look at doing or is it going to be fine now that it is stock?
Old May 7, 2007 | 02:44 PM
  #45
midiwall's Avatar
Looks like we all kinda' left you hangin'... whoops.
Umm, you should REALLY get some fuel mods on that engine. 7th injector, larger stock injectors, something... Do you have a budget for doing work on it?
89fourrunner
Feb 17, 2016 06:52 AM
TACOJO
Nov 27, 2015 05:26 PM
old87yota
Oct 25, 2015 02:15 PM
alexcarey
Oct 14, 2015 06:05 PM
travisamorgan
Sep 2, 2015 01:00 PM
