1 more new kid question
Old Jan 25, 2004 | 04:30 PM
sorry guys- i feel like a real ass asking this but its cold and my hands are numb and i dont feel like screwing around with it- how do i get off the corner lamp on my 90 4runner. The bulb is out, but i cant get the lamp out to get the bulb- thanks!
Old Jan 25, 2004 | 04:32 PM
Juggalo's Avatar
I haven't replaced any of my bulbs yet, but I'm sure somebody here will know.
See if you can find a diagram online that will show you exactly where everything is
Old Jan 25, 2004 | 04:40 PM
Yoter's Avatar
Guest
Get a phillips screw driver, and a flat blade screw driver or knife. dont cut yourself. unscrew the two screws on the side then take your flat blade between the headlamp frame (bezel) and gently pry the two separate. then turn the bulb plug counter clockwise until it stops then pull it out. remove the bulb then insert the new bulb and then replace the bulb plug. then you pop the male ends on the marker light into the female ends on the headlamp bezel. then screw it back to the fender and its good to go. Blue
Old Jan 25, 2004 | 04:43 PM
wow- you make me feel like a dip.... well- anyways- you get the point- thanks man- that helps lots!:pat:
jasonty
41
Dec 23, 2018 01:00 PM
Swim
9
Jan 4, 2016 10:47 AM
TJWilly
Jul 31, 2015 02:05 PM
Nailit69
Diesel Swaps
Jul 21, 2015 05:28 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
