1 inch Body Lift Installed *PICS*
Old Feb 18, 2008 | 07:11 PM
Rock Slide's Avatar
Got my 1” Body Lift installed a couple weeks ago. Purchased the steering extension from 4Crawler Off Road.
I also took a page out of Steve’s book at Sonoran Steel and installed a set of rear fender liners to cover the gap created by the BL . I then sprayed undercoating over the liners and the wheel wells to make every thing blend together. More info on what Steve did can be found here: Click Me.
I’m very pleased with the overall results of the BL and Fender Liners . Pictures below:
Body Lift and Steering Extension:
Before:
Body Lift Installed:
Steering Extension Installed:
Here’s some info on the rear fender liners that I used to cover the gap created by the BL:
- Wheel House Seals (2), Part No. 65675-89111
- Clips (9), Part No. 90467-A0003
These Liners have 5 holes in each. I had to create an extra hole on the passenger side fender…so I used a total of 6 clips on that one. However, for the driver side fender, I only used 3 clips. I used 2 existing clips that hold the gas tank filler cover to the body.
Fender Liners
Clips:
Rear Driver Side Body Gap:
Rear Driver Side After Liners Installed:
Passenger Side Body Gap with New Holes Drilled:
Passenger Side After Liners Installed:
One Last Picture for Good Measure:
Old Feb 18, 2008 | 07:37 PM
Sloan's Avatar
looks great, your 4runner gets better and bigger looking every time i see it.
Old Feb 18, 2008 | 07:50 PM
Fo_SheeZy's Avatar
Looks awesome!!
Old Feb 18, 2008 | 07:56 PM
Djlarroc's Avatar
Nice job man, but did you really need the steering extension? Just wondering cuz altough my truck is a 1st gen, I didn't use an extension for my 1" BL.
Old Feb 18, 2008 | 08:20 PM
4rnr4nick's Avatar
Ditto on what Sloan said...
How long did it take to install? and did you need anything unusual (toolwise)?
Old Feb 18, 2008 | 08:23 PM
94Runner4x4's Avatar
looks awesome! but x3 on the steering extension. I put on a 1" from 4crawler and had no need for one although i do have a 2nd gen.
Old Feb 18, 2008 | 09:05 PM
Psalm 112's Avatar
On his website only 3rd gen's (and newer) call for an extention with a 1" BL. I got one with the kit I ordered last year from 4Crawler. Easy Install!
The Lift looks great RockSlide. Nice Rig!
Old Feb 18, 2008 | 09:22 PM
infiltrator's Avatar
and whats with the liners???
Old Feb 18, 2008 | 09:52 PM
4rnr4nick's Avatar
I think the liners are just to keep it looking pretty in there...GREAT idea, IMHO...less dirty stuff showing
Old Feb 19, 2008 | 03:30 AM
terminator's Avatar
The gap with the bumper doesn't look bad either, I was a bit worried but looks fine. I have a T15 for my 96 T4R so I wasn't sure about the 1" BL but now I am. Do you have a suspension lift as well and if so what are you running?
Old Feb 19, 2008 | 04:29 AM
mkgarrison5's Avatar
how much did the 1 inch body lift cost? how much does it usually run to have them installed too? i have been debating about a very small lift like a body lift. i wonder if they make a 1/2 inch body lift lol.. the only reason why i want one is so that my 265/75/16's wont rub at full flex and the wheel turned.
Old Feb 19, 2008 | 04:31 AM
Sloan's Avatar
yea gap guards always make stuff with body lift look ten times better IMO, i had a friend with a tahoe with 2 inch body and the gap was terrible.
the only think you need now for your truck rock is to get rid of that ugly auburn sticker and tag on the back and you'll be good
Old Feb 19, 2008 | 05:31 AM
My 1" lift cost me $95 from 4crawler. Install it yourself it's easy and you get good knowledge. Also, you put it on so you'll feel better about it and the best part, IT'S FREE!
Old Feb 19, 2008 | 05:47 AM
Mason Dixon's Avatar
the only think you need now for your truck rock is to get rid of that ugly auburn sticker and tag on the back and you'll be good :bigok:
and the front! Hard to believe a barner's truck could look so good! j/k Nice job man!
Old Feb 19, 2008 | 06:12 AM
neq0323's Avatar
looks good! are any of your harnesses stretched bad? i was wanting to try the same setup but i have an automatic and was woried about levers and brackets being to far streched.
Old Feb 19, 2008 | 06:24 AM
isaac338's Avatar
if you have any tools it's pretty cheap to make the lift yourself. i think i spent about $20 on UHMW, and maybe an hour on the jigs to slice and drill it.
dangit, i had a pic of all my pucks but i have no idea where it is. oh well, they look identical to all the other ones :d
Old Feb 19, 2008 | 06:30 AM
pitpatt's Avatar
looks really good man, the gap between the bumper and the rest of the body is not bad either which is a plus!
Old Feb 19, 2008 | 06:35 AM
yotasavg's Avatar
very clean runner!
Old Feb 19, 2008 | 07:03 AM
disassemble's Avatar
i've been considering the 1" BL for a lil time now, but with my new ARB it sits so nice flush... i feel like i don't want to ruin that, how are you dealing with it? or are you just over it.. hah... i have 275/70/16 and still rubs with my SAWs... dunnno so i wanted to get a 33" mud tire, and i figured a 1"BL would give it just enough room to be happy... anywho looksgood!
Old Feb 19, 2008 | 07:45 AM
Nate08's Avatar
Looks good.
