Yota 3.0's 1992 Pickup Build-Up Thread
Old May 31, 2011 | 09:03 AM
  #201
Greg_Canada's Avatar
Nice build dude, hopefully i get to see it in person, maybe we can do a fun race, built 3.4 vs built 4.0
Old May 31, 2011 | 05:55 PM
  #202
Dras16's Avatar
OK so I know I PMed you about this but How about some pics of your anti wrap bar!
Old Jun 2, 2011 | 09:52 PM
  #203
James Woods's Avatar
I first read through your thread when I first joined YT and I thought then that it was awesome and I still do, I just picked up the magazine and noticed your truck right away and realized I hadn't looked through the thread in a while. I love the truck and congrats on the cover.
Old Jun 7, 2011 | 05:00 AM
  #204
Yota 3.0's Avatar
haha sure! if you feel like driving 14 hours to get here from Toronto then sweet!!
I ve been so busy lately, i havnt finished it yet
Thanks man!
Ok so I started having some issues with my truck lately....Does anyone know where i can get a super tough 3VZ clutch? the V6 marlin HD one is no longer willing to hold up to a supercharged 1UZ, who would of thought haha. I know Marlin makes a competition clutch for the V6 but i dont know if it will hold the torque..
any info will help big time!
Thanks guys
Old Jun 7, 2011 | 05:46 AM
  #205
RBX's Avatar
RBX
The guys swapping in the VW TDIs are having problems also(due to high torque), but it seems to be remedied by a 1600lbs Aisin, IIRC that is the Marlin HD. If that is what you currently have, i am guessing you will need to go to the comp style/puck clutch?
Hope that helps
Old Jun 7, 2011 | 05:48 AM
  #206
toyminator2000's Avatar
Thanks guys
Look in to a Centerforce dual friction. It has kind of a harsh feel to it when it engages but it sticks like glue.
Old Jun 7, 2011 | 07:05 AM
  #207
Yota 3.0's Avatar
thanks for info guys, i apprecaite it..
Thanks Toy, ill do some more research on the centerforce dual friction. is that what your running?
Been reading around all morning, Centerforce, SPEC, and Competition Clutches seem to be the only ones that offer anything other than a "better than stock".
SPEC actually offers a stage 5 unsprung clutch for drag race use only. i dont think i want that.
Competition offers a stage 5 sprung 4 puck clutch for $320.00
just sharing some info for anyone who is having the same issues.
James
Old Jun 7, 2011 | 08:41 AM
  #208
I ran one when I had my 4cyl. I only had a single t-case and 37" boggers and it absolutely wouldn't slip. Like I said the engagement wasn't as smooth as I would have liked but it was tolerable since it wasn't a daily driver.
Old Jun 7, 2011 | 08:57 AM
  #209
Yota 3.0's Avatar
Thanks Toy! ya i wouldnt mind if the clutch was harsh or had a stiff pedal feel as long as it held the power and wasnt unsprung. I appreciate the info.
Here is a bit of an update after emailing and calling around:
Competition Clutch - the website says they offer clutches for pickups and 4 runners but after emailing them, all of that is discontinued and they no longer make it.
Centerforce - the highest torque rating they can support using a 3vz flywheel is 330 f/lbs, they guy told me to go on summit racing to order because it was $100 less, sure enough it was $409.00 part number DF501110
Spec - they make a stage 5 clutch that will hold 505 f/lbs but it is unsprung, the stage 4 is good for 380 f/lbs but it is unsprung also. They do make a stage 3+ which is good for 420 f/lbs and is sprung. part number ST593F.
Found one on ebay for $494.00
I will most likely go with the SPEC stage 3+ unless i find something better by the end of the day..
I hope this information help someone else some day.
Old Jun 7, 2011 | 10:14 AM
  #210
Spec are nice clutches, especially if you dont want to swap to a 5vz flywheel.
I'm running a clutchmasters stage 4 in my s/c'd 3.4 IIRC it was around $400-450 US. It's supposed to be good to 500lb-ft i believe. It's 6 puck, sprung, super HD pressure plate. I ordered it from www.paradiseracing.com 5vz clutch tho.
Can you swap to 5vz flywheel? Then you can run a multitude of 5vz clutches. URD sells stage 2, 3 and 4. http://www.urdusa.com/More-Products-...4mi8p86h42q6d4 and are great to deal with.
Don't go centerforce... you will be disappointed... heard too many horror stories.
I would go for a stage 4, 6-puck sprung clutch if i were you...
As per the other comment,
14 hours away? Jesus... i thought someone said Barrie....
Old Jun 7, 2011 | 04:48 PM
  #211
exist's Avatar
Could you not machine the flywheel for a different pressure plate bolt pattern and run 5vz pressure plate / clutch ? Or are the splines different as well?
I wonder how different the flywheels really are in the end and if it would be worth it to run 5vz stuff compared to upgraded 3vz clutch stuff? I guess you gotta crunch some numbers and figure out how much it would cost to run 5vz/upgraded 5vz stuff compared to limited 3vz stuff..
Old Jun 8, 2011 | 05:09 AM
  #212
The overall diameter is the same,, but i believe the contact patch is a bit bigger. Otherwise, they're about the same.
Old Jun 8, 2011 | 05:15 AM
  #213
Yota 3.0's Avatar
im not sure if the ring gear teeth will match the lexus starter. i think the wrong side is beveled..
Old Jun 9, 2011 | 05:27 AM
  #214
I wish i took better pictures when i had the two together...
but you can you either or (3vze of 5vzfe) flywheels in a 3.4 swap, as long as you use the correct clutch. They both use the same starter / mounting / etc.
Old Jun 9, 2011 | 05:41 AM
  #215
jordan88runner's Avatar
nicest pickup i have ever seen! great build up
Old Jun 14, 2011 | 07:02 PM
  #216
theduck911's Avatar
Was that your 2nd Gen I saw today?!
Old Jun 15, 2011 | 04:15 AM
  #217
Yota 3.0's Avatar
^ sure was
Old Jun 16, 2011 | 12:04 PM
  #218
theduck911's Avatar
^ sure was
Looks good man!
Did you paint your grille yourself?! and where'd you pick up the sport hood?
Like the FJ wheels, I see blue in the front wheel wells, you running a pro-comp type kit?!
Old Jun 16, 2011 | 01:27 PM
  #219
4.0 Pickup's Avatar
Yeah. The Taco looks great bro. Did you installed a leveling kit or only tires? Those wheels makes it look OEM but diffrent from others. Like a special edition hehe. Also, are those the stock healights? Mines are chromy?!?
Old Jun 16, 2011 | 01:39 PM
  #220
Yota 3.0's Avatar
Thanks Theduck and David
The grille is new oem, the hood is new from T&T Auto and Mascarins painted it, the scoop is oem, the shocks are King coilovers front and King shocks rear. The headlights are factory with custom retro projectors and painted black.
I have all of my oem stuff i took off if u know anyone who wants anything. The shocks I took out are bilstiens.
