xxxtreme22r's 1987 Pickup Build-Up Thread
Old Oct 17, 2011 | 11:56 AM
  #1161
ChefYota4x4's Avatar
Any update, B? I say keep hunting on the gear angle.... You'll find em, man. Just so I'm not making an arse of myself any further, unnecessarily, ..... "YOU ARE looking for 4.88's for the rear, right?????" lol. I figured you have the front gears.. just need a rear one.
How bout the frame, what's the plan?
Old Oct 17, 2011 | 11:58 AM
  #1162
xxxtreme22r's Avatar
no plan for the frame yet. Most likely just replate over it like the rest of it. And yup, need 4.88 rear now.
Old Oct 17, 2011 | 05:12 PM
  #1163
1986yota4x4's Avatar
just read your whole thread, i love your truck, i also picked up a 4.88 front diff for my truck for a song lol, i was told to talk to you about adjustable cam gears. i had my 22r head shaved .14 and was wonderin if i would have any problems with just a regular cam gear?
Old Oct 18, 2011 | 03:34 AM
  #1164
.14 is alot even with mine being .10 I think I need that cam gear. You can run without it, but it might sacrifice some bottom end grunt for mid-upper power. Mine noticeably wakes up above 2800-3000 anything below that lets just say I am glad I have a manual trans and 4 lo.
Old Oct 18, 2011 | 11:08 AM
  #1165
Anyone ever bend one of these?
45612 ARM, STEERING KNUCKLE, LH 45612-35150 1 1985.08-1989.03 LN66, RN6#, VZN6# $56.55
Old Oct 18, 2011 | 11:30 AM
  #1166
RBX's Avatar
RBX
Impressive, I'm pretty sure that is a cast piece you bent. And no, sorry haven't bent one. I'll give you mine when I do my sas, but that may be a few months.
Old Oct 18, 2011 | 11:38 AM
  #1167
I wouldn't say bent maybe tweaked would be the proper term. But remember a while back I had said I went wheeling and hit a hole pretty good and blew a bead and my steering wheel ended up a 1/4 turn off?
Well it appears that that side's tie rod is sitting closer to the frame then the other side
I think the pitman is slightly tweaked too. Not too worried about that as it's a lifetime from AZ
Then I can't tell but I believe the very end of the relay rod isn't "squared up" either.
The odd part of that part number is the fact it only covers 86-89. 90+ is a different part number. I wonder if this is like the Idler arm thing where they made a beefier one later on or this one was only made for the manual steering trucks. I got some poking around to do. lol.
Also while I am thinking about it, I believe even though the front end parts were similar if not the same is that the later models had a different turning radius as well. But the stoppers are on the pitman and idler themselves not the knuckle arm.
Old Oct 18, 2011 | 11:55 AM
  #1168
RBX's Avatar
RBX
All those parts, sounds like it's time for an sas.
Old Oct 18, 2011 | 12:03 PM
  #1169
lol, nah. It's a note to self: Don't have 3 beers with your buddies before going out on trials. Especially when you hardly drink to begin with and 1 heep tries and the next looks and both then go around. LMAO.
Old Oct 19, 2011 | 02:51 AM
  #1170
92 TOY's Avatar
buy my caddy....take the motor out and put it in this------>>>> http://scranton.craigslist.org/cto/2657367809.html
Old Oct 19, 2011 | 07:04 AM
  #1171
Outsane's Avatar
I want those seats!
Old Oct 19, 2011 | 07:05 AM
  #1172
lol not a bad price for a rolling chassis. Too bad I don't have e money, I'd buy that and slap my 22r in it. It would be one of the only 2nd gen 4runners with a carb'd engine.
Old Oct 19, 2011 | 09:40 AM
  #1173
Originally Posted by Outsane
I want those seats!
I can't stand the 90+ 4Runner seats...... Just an FYI, in case you're a 'bigger than average' guy, like myself. IF NOT, ....then they'd be great, most likely. It's the bolsters, for the most part, ....they travel all the way up to the shoulders and cut into the Scapula(blade)..... They're tighter around the waist on the bolsters, too.
Sorry B, ... I know it was just a random comment, and I AGREE WITH OUTSANE... they're CLEAN! lol. But wanted to warn anyone to try them before thinking they're the same as the 85-89 SR5 Seats.
OK, .... I'll shut up now, lol.
Old Oct 19, 2011 | 10:05 AM
  #1174
john4wd's Avatar
I love the buckets in the 84 xtra cab I had, but they tilted back at an weird angle, so I put 1 1/2" risers in the back of the 2 rails and made a HUGE improvement and were perfect, I/m 6'2" and 255 lbs and they were perfect, I would love to get a set and center console for my 93 :} I Wonder if Toyota still offered them new? :} It would be cool and I bet expensive!!!!
Old Oct 19, 2011 | 10:09 AM
  #1175
I'd be happy to get rid of this bench seat and swap for a split bench. Oh yeah and thanks guys for getting my mind back on my crappy bench seat and looking for a split one.
Old Oct 19, 2011 | 10:42 AM
  #1176
EEEEEEK! .......... sorry B! lol.
Old Oct 19, 2011 | 03:44 PM
  #1177
92 TOY's Avatar
over here
https://www.yotatech.com/forums/f166...-101-a-243337/
Old Oct 19, 2011 | 05:09 PM
  #1178
Thanks Jerry, already know if I go with the toy 4.88 I get locked into that ratio.
Old Oct 20, 2011 | 03:33 AM
  #1179
92 TOY's Avatar
just trying to help with stuff i don't know
Old Oct 23, 2011 | 10:39 AM
  #1180
https://www.yotatech.com/forums/f100...2011-a-243489/
