xxxtreme22r's 1987 Pickup Build-Up Thread
Old Nov 4, 2011 | 05:17 PM
  #1201
xxxtreme22r's Avatar
the fluid that came out was dark, but it's been in there about a year or so. Wheel cyls are brand new. Shoes and Pads only a few months old (second set in that year) Rotors as new as the rest of the system. Only thing I never replaced or turned for that matter was the drums. Yeah shoot me now. lol.
Anyway. The way I am bleeding them is a homemade vacuum setup. Kinda like a catch can deal. Hard to tell if I am drawing all the air out or not because the hose I am using doesn't quite fit my bleeder screws. FYI shoulda got 1/4" clear tube and not 3/16.
Wont have money till Wed Jerry. And I got like 1/8 of a tank of gas an about $1.50 in cash.
Old Nov 4, 2011 | 05:23 PM
  #1202
92 TOY's Avatar
its ok i get paid thurs and wont have any money then either
i have several feet of oxygen tubing i cut about a foot off to bleed the clutch.
Old Nov 4, 2011 | 05:24 PM
  #1203
if it's 1/4" it'll work. lol.
Old Nov 5, 2011 | 09:22 AM
  #1204
Found the problem with me still "over heating". Bottom half of radiator on the inside. Yeah I think I need another pressure wash. LMAO.
Onto the brake issue.
Yeah I didn't need that bleeder screw anyway.
My handy dandy homemade one man "power bleeder"
This is what the fluid in the lines looked like after only about a year in the lines.
New Master Cyl coming soon.
Old Nov 5, 2011 | 09:37 AM
  #1205
ChefYota4x4's Avatar
Dang, that's some nasty 'no-go-go' juice! lol. also, ..... that pic of the radiator is HILARIOUS, lol. Oh well, ..... was worth it to you, I'm sure, with the fun you had making it that way, eh? lol.
Old Nov 5, 2011 | 04:58 PM
  #1206
92 TOY's Avatar
I think you need antibiotics.
bring the thing out here this week or this weekend (while it's still nice out) and we can pressure wash it
Old Nov 5, 2011 | 04:59 PM
  #1207
Someone that works at Autozone is gonna need painkillers. The good kind. Let's put it this way, I hate when people waste my time.
Old Nov 5, 2011 | 05:14 PM
  #1208
92 TOY's Avatar
did you go for your walk?
Old Nov 5, 2011 | 05:15 PM
  #1209
If I did someone woulda gotten hurt. FB.
Old Nov 7, 2011 | 08:09 AM
  #1210
New master cyl on, brakes bled and still pedal catches low unless I pump with vehicle running. Would a small vacuum leak in the booster cause a soft/low pedal on first pump? grrrrrrrr.
My idle does jump slightly and back down during brake pedal travel. But thought that should cause a hard not soft pedal. Kinda confused here. lol.
Old Nov 7, 2011 | 08:14 AM
  #1211
irab88's Avatar
too much mud
Old Nov 7, 2011 | 08:15 AM
  #1212
Brake lines are a sealed system. Just sayin. LMAO.
Old Nov 7, 2011 | 09:27 AM
  #1213
Hmmmm, .... well, the Booster COULD be, simply, getting worse(if it IS indeed leaking vacuum). Maybe after adding the pressure of a lotsa new goodies in the brake dept.... now the Master, it's just wanting to tear a lil more? Just guessing.... Did you do the booster test? (Pretty sure the idle thing is part of that test).... With a master you're sure is good... I think pumping while running, then holding it depressed, should cause it to slowly head toward the floor when it's a booster loosing vacuum/making things a lil soft.
Not sure if 'catching low' would be more of an 'adjustment' of master adjustment screw, rather than the booster. BUT, since you've done a brake swap(sorry, I can't remember off the top of my head.... Tacoma Master and booster?)... maybe it's just a clearance thing on the 'catching low' portion?
OR, maybe that 'adjustment' at some point pushed the booster to a point where it is pushing the diaphragm past it's comfy limit? lol.
Do you still have the check valve in there? Is it possible it collapsed and isn't allowing the 'vacuum assist' that you're needing?
Sorry man, just throwing it out there to see if it sparks something.
Old Nov 7, 2011 | 01:43 PM
  #1214
Yayyyyyyyyyy!!!!!!!! I think I gots my brake pedal back. Gotta test drive it yet, can't till I fix this damn tire that I have "issues" with the bead and mud and etc etc in it. But feels much better now. Musta been air in the front pressure sensing line going to the LSPV. Took the line off bled it that way. I am sure there is still a bit of air in there but it's 98% better now while running and sitting still at least.
Old Nov 7, 2011 | 04:25 PM
  #1215
WOOOOOOOOOOOT-WOOOOOOOOOOOT~ !!!!!! LOL. Congratz, man! You still planning on doing a good-deep pressure/cleaning? (thought you said you and Jerry were gonna clean that sucker up all over) hehe.
Old Nov 7, 2011 | 05:13 PM
  #1216
92 TOY's Avatar
wednesday seems like a good day.
Old Nov 7, 2011 | 05:34 PM
  #1217
Sounds good to me. Barb has off the next two days. So Tomorrow works too.
Just wait for me in Berwick, I might not be able to make that turn on Union street.
Did you get yur parts yet?
Old Nov 8, 2011 | 02:20 AM
  #1218
jeremys87yota's Avatar
mind me askin about that weber carb?about how much power does it add?
i got an 87 ext cab with 35s..i would like to get a lil more power, and i heard those weber carbs are decent. worth it ya think? they hard to put in? lol.
Old Nov 8, 2011 | 03:54 AM
  #1219
Today is out Jerry. No gas. Tomorrow I think is good.
It's hard for me to comment on the power added from the Weber as it was added shortly after a full rebuild. The adapter plate that comes with every kit available is junk. Buy the kit and trash the adapter and get the 1-piece adapter that trans-dapt makes or possibly the LCEngineering spiral adapter. Reason being the two piece is almost impossible to keep from getting air leaks in it.
If you running 35's and factory 4.10 gears, your best bet is to find yourself at least a 4.88 gear set for the truck. Whether it be ones from a 4runner or have ring and pinions put into your current ones. 5.29's are preferred though with a manual trans. It might seem expensive. But the amount of cash you'd have to dump into the engine power wise to turn those tires is gonna round out to be about the same amount of dough.
Old Nov 8, 2011 | 03:58 AM
  #1220
92 TOY's Avatar
today is out for me as well.
tomorrow looks OK...little guy will probably be home from school tomorrow...we will see.
NO, i did not order anything. may pull it in the garage again today and see if i can get that stuff off....if i can, i will check with autozone to see if they have that caliper. i imagine (tell me if i am wrong) i can just unload my caliper into the new caliper, since the pads look substantial and i had no brake issue before that. if that indeed is the case, i just have to worry about getting my caliper off, new one on and brake fluid.
